UPR Coil Over's with Strange Struts, maybe have to modify C/O sleeve?
LinkBack (2) Thread Tools
Old January 20th, 2011, 03:44 PM   2 links from elsewhere to this Post. Click to view. #1
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Alright i have my UPR K-Member kit and 14" 150LB springs and Strange struts to put in soon. I have a question about the C/O sleeves fitting the Strange struts. In the pictures the sleeve is only touching the strut on the bottom only about 1/2 of an inch. Is this normal or should i cut a small section out of the bottom of the sleeve so it fits down over the raised part of the strut so then the whole bottom of the sleeve will be touching the strut and be evenly dispersing the weight around the sleeve instead of just that 1/2in piece. Should i cut it or is that normal? Seems like if its not cut out it will bend the sleeve where all the weight it on that small piece of the sleeve. Any input?
Also i have the 3 bolt CC shark plates from UPR, will these have enough adjustment to get my alignment back straight or should i swap them out for some 4 bolt plates? I have not used the 3 bolt CC plates yet, there still in the box.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old January 20th, 2011, 03:49 PM   #2
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
my strange c/os have a notch cut out for the struts so they don't spin.
Old January 20th, 2011, 03:52 PM   #3
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
my coil overs also have a notch in them
cut them mother fuckers lol i would
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old January 20th, 2011, 03:52 PM   #4
BYAHHHH!
2001 Mustang GT
13.874
Who's using upr coilovers with strange struts - SVTPerformance
Old January 20th, 2011, 03:52 PM   #5
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
My MMR coilover kit had a notch alrady cut out for that. So I would notch it so it slides down all of the way. I have teh MM 4 bolt CC plates. Ive never used 3 bolt ones. Im sure you could get enough adjustment.
Old January 20th, 2011, 03:54 PM   #6
2004 Mustang
So you guy's sleeves have the notch cut out to fit over the bracket on the strut?
Old January 20th, 2011, 03:54 PM   #7
BYAHHHH!
2001 Mustang GT
13.874
yes sir. just cut them like that link I sent you from SVTP
Old January 20th, 2011, 03:57 PM   #8
2004 Mustang
See how the 3 bolts just slide one way and to move it the other way you cant just slide it, you have to move it down to the next bolt hole where as the 4 bolts can slide in a "T" direction.
3 bolt
94-04 Mustang Steel Shark Caster Camber Plates
4 bolt
94-04 Mustang 4 Bolt Caster Camber Kit Black
Old January 20th, 2011, 03:58 PM   #9
2004 Mustang
Awsome thats what il do, i looked at em and was like WTF is this???? I knew it would probably gank up the sleeve as soon as weight was put on it.
Old January 20th, 2011, 03:58 PM   #10
2002 mustang gt
12.2 at 117
i thnk youll be good wiht the three bolters
Old January 20th, 2011, 03:58 PM   #11
BYAHHHH!
2001 Mustang GT
13.874
the 4 bolt looks MUCH nicer. Check out the Team Z 4 bolt
Old January 20th, 2011, 04:01 PM   #12
BYAHHHH!
2001 Mustang GT
13.874
yeah true. it will chip the sleeve
Old January 20th, 2011, 04:27 PM   #13
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
I've been told by multiple suspension techs that you need 4 bolt CC plates to distribute the weight of the vehicle properly for new edge mustangs when running CO's. The triangulation of the 3 bolt plates causes the weight to only be distributed to the 2 outside bolts only. I would highly recommend a good set of 4 bolt CC's.
Old January 20th, 2011, 05:28 PM   #14
Willy Mo's Avatar
^ never thought about this but it is a good point.
Old January 20th, 2011, 05:34 PM   #15
2004 Mustang
Alright il cut that part out of the sleeve and i just got a RMA # and will be sending my 3 bolts back to UPR for some 4 bolts, thanks guys.
Old January 20th, 2011, 05:35 PM   #16
2004 Mustang
Also anyone else running 14" 150lb springs? If so how low is it and how is the ride?
Old January 20th, 2011, 09:23 PM   #17
BYAHHHH!
2001 Mustang GT
13.874
14 150 would be to soft for the street lol My suspension guy runs 14 175 on the a low 8 sec car. I have 12 200 that TeamZ uses
Old January 20th, 2011, 09:36 PM   #18
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
it should already have a notch. thats weird. mine did.
and i don't like my 150's...way to soft. had to raise it up really high to keep the spring from bangin around. weird thing is bullit5539 has the same setup and his doesn't do that. anyway, i'm switching to the 12 250's.
and in my personal opinion you'll be perfectly fine with the 3 bolt plates. jeremy from upr has plenty of people running that setup. and mine are workin just fine..
that being said, the four bolt plates sure won't hurt
cams + 150 shot
Old January 22nd, 2011, 12:27 AM   #19
Why would upr develop a set of 4 bolt plates if the 3 bolt plates were sufficient?
It also probably depends on how much stress your putting on them. I'm running 275/12's up front and autocross so the stronger I could make my strut tower, the better. I'm going up to 325's when I switch to a torque arm.
There is a big difference in fox cc's vs New edge cc's. Picture a triangle made by the 3 bolts on the plate. On a fox, the strut pertrudes up within that triangle, distributing the weight into all three bolts. On a new edge, the strut pertrusion lies outside this triangle, causing uneven weight loads. This is why the new edge mustangs require 4 bolt plates for CC's. The strut is enclosed by the bolts and stabilizes load distribution.
Old January 22nd, 2011, 10:45 AM   #20
Willy Mo's Avatar
mine are 185/14's work well for me.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/200561-upr-coil-overs-strange-struts-maybe-have-modify-c-o-sleeve.html
mustang coil over sleeve id | BoardReader This thread Refback April 19th, 2011 03:50 PM
Thread Who's using upr coilovers with strange struts | SVTPerformance | BoardReader This thread Refback March 12th, 2011 03:40 AM
Threads Similar to: UPR Coil Over's with Strange Struts, maybe have to modify C/O sleeve?
Will Strange struts work? 2VSouth 99-04 23 November 28th, 2010 03:04 PM
Strange Coil Over pacopatron 5.0 Mustangs 5 November 16th, 2010 07:05 PM
Strange Struts and Shocks I8ACMRO 99-04 17 April 9th, 2010 12:09 PM
Those with Strange Shocks and Struts Hawaiianbro 99-04 0 August 19th, 2008 04:52 PM
strange 10 way adjustable struts DILO2001GT General Tech 2 July 16th, 2006 11:31 AM
