LinkBack (1) | Thread Tools |
#1
2004 Mustang GT 40th
How many quarts of motor oil does a 2004 Mustang GT hold?
About how many quarts of motor oil will a 2004 Mustang GT hold?
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
11.6@118
i heard up to 7.
![]() 02' Mustang|MMR 4.75L 1000se|Vortech|pump gas|566rwph/511rwtrq. |
depends as some years had different dip sticks. i would just put an even 6 in it. you can put up to 7 in with the stock pan and no problems. if you have a high rpm car and are taking it to the track or something then i'd recommend 7, but for most 6 is good.
![]() '00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come. '95 GT, 347, tko, etc-11.8@116-sold. ![]() WTT-my mildly built 4r70 for t56/tko. |
Is your v2 tapped into your oil pan and do you run 6+ quarts of 5w20 or 6+ quarts of 5w30? Just curious
Too Soon, Junior!
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
6 Quarts, use 6.5 or 7 if you're a corner carver or launch hard. Usually there's .5 to 1 quart of oil left in the pan and engine after you drain the oil for an oil change. I use 5 quarts of synthetic and 1 quart of Lucas synthetic oil stabilizer.
![]() 03 GT - Scrapes on lane markers - Modded 02 Cougar - Able to clear most speed bumps - Some mods 01 Explorer - Parking blocks NOM NOM NOM - Stock Nitrous Switch Panel for sale! |
yes it is and i believe he usually has 6.5 quarts in there.
04 GT 5.4 DOHC Twin 67mm
umm the owners manual calls for 6 so i would run with 6
11.6@118
yes it is, only vortech that doesnt have to be tapped is the v3 and yes 6.5.
ok gotcha and i forgot there was just a few differences between the v1 and v2 I gotcha.
you guys running the vortech set up do you run 5w20 or 5w30 or does it really matter?
12.85 @ 114
6 unless you got a oil fed blower, then its more like 6.5 qts.
5 is not enough; at least for any 03 or 04 I use whatever oil the manual calls for (motorcraft synthetic blend, 5w30? dont remember the weight, whatever it says on the manual for an 04)
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
my 03 says 5w20 on the oil cap.
I run 7. I have a cobra BTW. Heres why:
Oil pan capacity test pics - SVTPerformance For those who didnt click the link, 6 quarts in an oil pan:
^ thats my reasoning too. 7 qts and it's still below the crank scrapers a tad, and when it's running there's never all that oil sitting in the pan, even just at idle i'd say there's atleast 2 quarts up top
How much will it hold or how much should you put in it? It will hold 9 quarts to the brim. My manual calls for 6 quarts. I ran 6 quarts for the first two years that I had the car, but the oil on the dipstick was always between minimum and half. I later started to put 6.5qts into it, which brought it up to half way on the dipstick. Now with the supercharger I run 7 quarts, which is right at the top of the dipstick.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
I ran 5w20 N/A. Now I run 5w30 Castrol GTX.
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
Mine held 6.5 on the stock pan.
1989 LX Coupe
7.1@99mph
Bottled2V is right...only change for the Cobra and GT is the dipstick. 7 qts is fine...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
04 mustang gt
7.21 @ 98
i fill it till its just below the max line. or right at it...
whichi s 6.75 quarts
![]() cams + 150 shot |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/200572-how-many-quarts-motor-oil-does-2004-mustang-gt-hold.html
| Thread How many quarts of motor oil does a 2004 Mustang GT hold? | Forums at Modded Mustangs | BoardReader | This thread | Refback | June 27th, 2011 10:21 PM | |
Threads Similar to: How many quarts of motor oil does a 2004 Mustang GT hold?
| How many quarts? | mystang0673 | 99-04 | 18 | April 17th, 2011 11:58 PM |
| Would A 2004 4.6 Gt motor fit in a V6 1999 mustang?no wireharness just computer | TX77 | 99-04 | 16 | November 20th, 2010 08:01 AM |
| help...... how many bolts hold the t45 to the motor?????? | auggydoggy502 | 99-04 | 9 | August 29th, 2010 09:36 AM |
| Should I hold off trying to upgrade my current 2000 mustang | mustangv600 | V6 Mustangs | 10 | June 18th, 2009 08:23 PM |
| how many quarts does 5.0 hold | j2000_guy | 5.0 Mustangs | 4 | August 22nd, 2006 12:37 PM |
