2002 Mustang GT 4.6L
Dry/Rough Shifting
Alright here is the back story. Car had nearly 80K miles on it so I wanted to change the transmission oil. Was going to do the whole Pennzoil synchromesh and some lucas. However the store was sold out of synchromesh and no one was in stock around town. So popped over to the dealer and they sold me mercon V.
Shifting was great for the first month but it just continued to get worse after that. It’s not smooth at all now. I can feel the gears when pushing in the shifter and at times have to double clutch just to get the transmission in gear. Fluid level is good and the situation does slightly improve as the car warms up but not much better. My plan is to drain the mercon V and find some synchromesh. Or is this a waist of cash and time? Thanks for the advice.
![]() Steeda UDP, K&N CAI, FlowMasters 40’s, Polly Mounts, Aluminum D/S, Chrome Moly Flywheel, Centerforce DF, MM (quad, cable, adj.), Lakewood LCA’s, MM FLSFC’s, Predator canned 93 tune. |
99' Vette, 02' Mustang GT
![]() ![]() iTrader: 8 reviews
Well, mercon V and synchromesh are both very good. I wouldn't believe it to be the mercon v that causes the issue since there are plenty of guys here that use it. The 3650 is naturally a little notchy, but it could be a couple things that cause it to shift roughly. Has the shifting feel changed dramatically after that first month all at once or just slightly/ gotten worse over time?
'99 SVT Cobra - 283 C.I. WAP Forged Block, HP Custom Blower Cams, Novi 2000rr (8-Rib) + 20 psi, RPM T-56, SRA Swap '99 C5 Corvette FRC - H/C/I/E + Suspension '02 Mustang GT - Exhaust, 4.10's, Suspension SOLD
1998 mustang gt
Dry and rough- sounds like my last sexual experience! Lol! Sorry I have no tech knowledge for you op, just a little humor!
MILITARY CREW EX-US ARMY SSG |
^ Well, that doesn't sound so pleasant, should have lubed up!
1998 mustang gt
The more lube the better!
It was great after I did the change. Then as the weather cooled down it got harder and harder every week to put it in gear. So I knocked it up to cold fluid since it got a little better when the tranny warmed up I would have to say steadily worse over time but it seems to have hit a plato and not getting any worse.
Did some more research last night and started to lean towards quadrant because I get noise some my pedal time to time. Adjusted it this morning and was a slight improvement. *have stock plastic quadrant
Threads Similar to: Dry/Rough Shifting
| rough shifting :o ?? | Ochoa | 99-04 | 12 | September 26th, 2010 01:12 PM |
| rough cam.... | Bullitt73 | 5.0 Mustangs | 4 | August 13th, 2010 12:41 AM |
| My car is running rough | 99BlackBetty | 99-04 | 6 | January 6th, 2009 01:49 PM |
| Rough Shifting.... | lwhitetrash88l | 5.0 Mustangs | 19 | October 6th, 2007 08:51 PM |
| Running Rough | 92mustanglx | 5.0 Mustangs | 5 | April 6th, 2007 06:44 PM |
