code PO155????
Old January 20th, 2011, 07:57 PM   #1
2000&95 mustang GT
tanner.GT is on a distinguished road
Exclamation
code PO155????
hey guys I just put a motor out of an 01 into my 2000 runs amazing by the way but I originally had an off road h pipe and flowmasters but with the motor swap I went to longtubes and an off road x pipe...long tubes were a pain in the ass to put on by the way...but since then the code PO155 has popped up I keep deleting it but I keeps popping up its on bank 1 sensor 2 but I have a exhaust leak at the drivers side header wuld this cause this code also I barely got ny 02 sensor on that side hooked up I almost had to stretch the wire to get to it culd it of caused a short? Or should I just replace the 02 sensor?
Old January 20th, 2011, 08:13 PM   #2
1_nice_03_gt's Avatar
2003 ford mustang gt
13.9 stock
1_nice_03_gt has a spectacular aura about1_nice_03_gt has a spectacular aura about
u didnt get extensions for the 02 sensor? it probably not readying the sensor n on my obd2 thing its readying your code is bank 2 senor 1. idk man imma let the real gear heads jump in on this one, my .02 is buy the extenstions n new 02 sensors
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
Old January 20th, 2011, 08:42 PM   #3
2000&95 mustang GT
Na man. I just ordered them on ebay......but I'm bout to replace the 02 sensor and I was told it mite b my exhaust leak by the header its quite noticable I'm hoping I dnt have a short in my wiring
Old January 20th, 2011, 09:58 PM   #4
carnut59's Avatar
2001 gt
carnut59 is on a distinguished road
yes an exhaust leak can throw a o2 sensor code. fix the leak, put the extensions on. only replace the sensor if the light comes back on.
Threads Similar to: code PO155????
DISCOUNT CODE DELETED - New Code Available - Please Read! AMNick American Muscle 86 May 14th, 2012 08:22 PM
How to Fix Airbag Code and EGR Code ModMustang97GT 96-98 2 April 10th, 2011 10:17 PM
SES light-code P1401 code-& DPFE sensor ?'s PacificMustang01 V6 Mustangs 6 May 18th, 2010 02:39 PM
Po155 05MustangGTR 2005 - 2010 1 September 20th, 2009 11:32 PM
PCM code noppe180 96-98 14 April 24th, 2007 06:13 PM
