2001 Mustang GT Vert
Average
Hard to shift
so when im driving "normally" not going past/ or around 2k rpms its kind of hard to put it into gear, but its not that bad, when im driving going past 2k rpms its a real bitch to change gears.
is that the clutch cable, because the firewall adjuster is turned all the way out. and i think i might have to adjust it from the transmission |
!FACEPLATED!
sounds like its cable related. Does it happen in all gears?
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
2001 Mustang GT
![]() ![]() ![]() iTrader: 3 reviews
You'd be suprised how much a fluid change helps, feels like a whole new tranny now.
![]() True Blue Crew Member #2 315's Crew Member (Dat azz) 255/298 Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club |
Average
yea, its in all the gears, and its really hard if im shifting hard, but the transmission oil was changed not to long ago, but i did by some lucus transmission oil for next time though.
2001 Saleen Mustang
12.4@108
change the fluid again, and get a new cable. bet that fixes it
Average
heres a little update, i didnt change the fluid yet, since it was changed not to long ago when the engine was replaced, and the clutch cable is new to my knowledge.
what i did was, i screwed in the firewall adjuster back to the firewall, then went under my car and took off the dust cover and a nut had fallen out, that nut was the "locking" nut to the cable.... i think... there where two nuts in all, and when i looked up how to install a new clutch cable, in the pictures there where just two nuts next to each other, sooooo i screwed it back together, and i screwed it on tighter, to were i could barley put the dustcover back on. then i readjusted at the firewall. i took it for a spin and this is what happened, it shifted fine when going slow, but when i stepped on the gas, it was hard to take out of first gear (it wouldnt come out untill the rpms lowed) and so on through out the grears, i parked it went to the store came back, and then when driving it just kind of felt like i had to jam it into gear. i have a steeda short throw shifter, if that helps too |
Threads Similar to: Hard to shift
| second gear hard to shift to | Nossit | 99-04 | 18 | June 17th, 2009 08:38 PM |
| hard to shift | dennydaman | 5.0 Mustangs | 14 | June 16th, 2009 10:44 AM |
| Hard first shift in tranny | tangbang | V6 Mustangs | 4 | October 20th, 2008 08:25 PM |
| knock when i shift hard | faon | 99-04 | 3 | January 5th, 2008 02:18 PM |
| hard shift | the tick | 5.0 Mustangs | 14 | September 13th, 2007 06:42 PM |
