ABS on solid rear???
Old April 18th, 2007, 07:26 PM   #1
fastvenom01 is on a distinguished road
changed the rear end out in my 01 svt to 8.8 solid from a 01 GT its on the road but not sure on what to do with the ABS cable its in a different location than the IRS was any ideas thanks
i have finally upgraded to THE SVT
Old April 18th, 2007, 07:38 PM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
the cable should be fine it should just have a different abs sensor end. I just helped with a swap and we had to use the abs cables off the old car cause the cobra ones wouldn't work.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old April 18th, 2007, 07:53 PM   #3
the orignal IRS cables are very long they were mounted next to the diff opposed to the solid which are located next to the hub the svt abs sensor seems to be a lil long it touches the abs gear when i tried to mount it although it looks like it could bolt up with a shim or something???
but thanks for the help
Threads Similar to: ABS on solid rear???
Solid motor mounts darkest hour 5.0 Mustangs 19 October 6th, 2007 07:00 PM
Solid lifters JBIGBOOTSY 5.0 Mustangs 4 September 21st, 2007 01:39 PM
solid swap SWEET2KSTANG 99-04 2 September 12th, 2007 02:26 PM
solid or urethane? 00vabchgt 99-04 3 August 7th, 2007 07:22 PM
I Need A 2000 And Up 8.8 Rear End (Solid) HELP! SICKPWR Modular Mustangs 2 November 22nd, 2006 10:40 AM
