driveline issues
So the whole transmission/driveshaft/differential is making me not like my car and get rid of it for a bimmer again.
When i push the clutch in ALL the way and put the car into gear, it will clunk into gear a lot of the time. it is not coming from the transmission, but from the rear end. What can be causing this? When the clutch is fully disengaged what can cause this to happen? Also, when i had the car up in the air not that long ago, if i turned on of the rear wheels, there was a lot of slack before the other would start turning. Does this mean that my rear end is shot? Oh yeah, and my throwout bearing from the new clutch i put in only a few thousand miles ago has gone bad already...
(I traded a bimmer for my mustang too) lol
Check the U-joints. You could have excessive backlash in the rear gears. But check the u-joints first. Although this still doenst fix why it clucks when the clutch is all of the way in an you shift into gear. Check your clutch cable adjustmant. Pull up on the clutch pedal to tighten it up a little.
Resident Diabetic...
06' GT
13.829@103.49
![]() ![]() iTrader: 2 reviews
I have a similar issue at the moment and I suspect it is u joints. Willy Mo makes a good point. Start there first. They are cheap and new ones couldnt hurt.
On a side note, every time I drive a Bimmer I want to buy one.
2006 GT-3.55's, Pypes Muffler Delete, PIE Aux Port, GT500 Pedals, Hurst STS, GT500 LCA's, 55D rear springs, FRPP A arm brace, Diablo 93 Tune. ![]() motortalkblog.com |
2002 Mustang GT 4.6L
*Subscribed
I have back lash from the rear end as well. Have replaced the drive shaft with an aluminum one and changed the diff fluid. The fluid change helped the grinding popping noise from the diff when making swooping turns. But still get a whip from the rear.
![]() Steeda UDP, K&N CAI, FlowMasters 40’s, Polly Mounts, Aluminum D/S, Chrome Moly Flywheel, Centerforce DF, MM (quad, cable, adj.), Lakewood LCA’s, MM FLSFC’s, Predator canned 93 tune. |
2001 Mustang GT
clunking could be the U joints, there are 2 and they can and often go, any odd vibrations?
My guess is the u joints as well. Anyone know where the best ones are for a decent price? I would rather order american made quality parts versus getting cheap chinese ones from the auto part store?
#7 | |
2001 Mustang GT
Lakeland makes a set avail on summit or american muscle for 20.99 a piece
sometimes i wonder myself lol. I had a 98' 328is. Silver with black leather interior. Best handleing car iver ever rode in, none the less drove. It was pretty quick for what it was, but best 1/4 pass was high 14's. I am a ford/mustang guy at heart and wanted a mustang more at the time. But damn do i wish i still had that car!
i would kill for mine back.
'92 325is coilovers headers exhaust short shifter projector HID's chipped the list goes on. Thinking about it makes me sad...
2004 Mustang
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Does it clunk harder when your going into 1st gear while rolling? If I'm rolling to fast and try to put it in 1st my car clunks from the rear with the clutch pushed in.
![]() 305/333 WHP/WTQ with CMS Stage II cams 440/552 WHP/WTQ on Spray 7.86 @ 89.1mph, 1.61 60 foot N/A 7.20 @ 98.8MPH 1.55 60 foot on spray Stock Longblock with Cams |
it does it when im rolling or not. i do feel a decent amount of what feels like the driveshaft picking up slack when i let the clutch out when changing gears. This sounds like u joints i think.
Which clutch did you install? Sometimes the TOB goes prematurely because the clutch isn't adjusted properly. Mine went prematurely because I had some bent fingers that the TOB was riding on. The TOB should not be touching the diaghram when the clutch is released.
i bought a fidanza 2.1
are there any issues that could arrise from not replacing a bad TOB?
Threads Similar to: driveline issues
| Crown Vic Driveline | jonnyspeed | 99-04 | 2 | November 29th, 2010 10:29 PM |
| 99-04 V6 driveline in a Fox mustang ? | daedreamah | 5.0 Mustangs | 4 | September 15th, 2010 10:17 AM |
| Slack in the Driveline? | AggieStang | 99-04 | 3 | September 7th, 2010 06:04 PM |
| driveline | moosenuk17 | 99-04 | 9 | May 26th, 2010 09:46 AM |
| Driveline Clunking | dumps | 2005 - 2010 | 9 | March 17th, 2007 05:21 PM |
