supercharged '01 Bullitt valve float? - Page 2
Old January 22nd, 2011, 06:28 PM   #21
CougarBullitt6801's Avatar
2001 Bullitt
CougarBullitt6801 is on a distinguished road
Just ordered myself a set of NGK TR6 V-Power Spark Plugs
'68 Cougar, non-XR7, 289/3spd
2001 Bullitt #185 (410rwhp/399rwtq)
Last edited by CougarBullitt6801; January 22nd, 2011 at 06:48 PM. Reason: wrong link
Old January 22nd, 2011, 06:51 PM   #22
'01 Gt Vert auto
13.2@103.8 n/a Stock stall
eddy21x will become famous soon enougheddy21x will become famous soon enough
keep up updated
253rwhp 294rwtq motor
337rwhp 427rwtq 90 shot
Old January 22nd, 2011, 07:01 PM   #23
2001 Bullitt
Will do
Old January 22nd, 2011, 07:54 PM   #24
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Gap them around .032.
Definitely check how much timing is in it, your maf counts, and fuel pump duty cycle. Does the Vortech kit come with 36lb injectors and the Walbro pump?
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old January 22nd, 2011, 07:57 PM   #25
ytngt has a spectacular aura aboutytngt has a spectacular aura about
For a factory longblock it would not hurt to go two steps cooler and non projected.
BR7EF
NGK Spark Plugs 3346 - NGK Standard Series Spark Plugs - Overview - SummitRacing.com
Old January 22nd, 2011, 08:09 PM   #26
2001 Bullitt
Ok, gap was gonna be my next question.
Yes, the Vortech kit came with 36lb injectors and the Walbro pump.
Old January 22nd, 2011, 08:35 PM   #27
blownstang's Avatar
The Walbro pump is a return style pump, which should not be used in a returnless style fuel system. It can be made to work, but you're running a risk of failure. I'm guessing your fuel system is pretty much maxed out. I'm running cobra 39lb injectors (rated to 42lbs) with an svt focus fuel pump and my pump duty cycle is 92% at 356rwhp. My guess is that you're way over 100% duty cycle on that Walbro pump. Look into swapping it out to an svt focus pump and possibly adding a KB 40 amp boost a pump. Check on that maf too as the 90mm lightnings usually peg at 400-425rwhp.
Old January 22nd, 2011, 09:17 PM   #28
2001 Bullitt
Duty cycle is something I have overlooked. Yeah, I'm pretty sure my pump is working overtime. I've misplace all the paperwork and charts from JBA. I think I do remember them saying something about upgrading my fuel system, but this was over a year ago.
For now, I will install the one step colder plugs, have the timing looked at, and lay off WOT. I will definitely look at getting an SVT Focus pump and KB bap once I can get some extra funds. But right now I can't afford any downtime with the Bullitt since she's my dd. I could use my '68, but she's not too reliable as a dd at the moment.
Thanks for the info
Old January 27th, 2011, 10:13 PM   #29
2001 Bullitt
Got the new plugs in the mail. Will be installing them this weekend...
Threads Similar to: supercharged '01 Bullitt valve float?
Supercharged Bullitt - Stumbling/Mis-firing M3Killer 2005 - 2010 16 January 9th, 2011 02:10 PM
Bullitt Valve Cover Help S281 99-04 3 June 22nd, 2009 06:37 PM
My Bullitt #1696 Supercharged nd4spd 2005 - 2010 42 December 14th, 2008 04:29 PM
