supercharged '01 Bullitt valve float?
Old January 21st, 2011, 06:58 PM   #1
CougarBullitt6801's Avatar
2001 Bullitt
CougarBullitt6801 is on a distinguished road
I haven't posted on here in quite a while. There's something about my car that's been bugging me for some time now. Lemme start with my setup.
tuned by JBA in San Diego (91 octane tune)
410rwhp@6477, 399rwtq@4827
Vortech S-trim, 3.33" pulley, aftercooler
90mm MAF
stock 4.6 2v
stock heads
upgraded fuel system that came with Vortech kit
stock oil pump
stock 3650
(I'm not entirely sure what clutch/flywheel the original owner installed)
FRPP aluminum d/s
FRPP 3.73s
stock Bullitt suspension/rear-end
stock exhaust manifolds/h-pipe
Magnaflow catback
wheels: 17x8 (245/45) front, 17x10.5 (315/35) rear
a little over 35k miles on her now
Now, the issue. Whenever I go WOT and the rpm's go past 5k, I hear a "metallic shard-like grinding" sound coming from the engine bay. My buddy says he thinks it's probably the valves or springs floating. According to the dyno sheet, PSI climbs from 7.5 to 11.5 from 5k to 6400 rpm. It's kind of odd how the PSI drops to 6.0 at max recorded hp @ 6477 rpm.
Is this valve float or something else? My Bullitt is a daily driver, and performs fine under normal conditions.
'68 Cougar, non-XR7, 289/3spd
2001 Bullitt #185 (410rwhp/399rwtq)
Old January 21st, 2011, 07:33 PM   #2
ytngt has a spectacular aura aboutytngt has a spectacular aura about
I am no expert on valve float. Please do not go wot until you can get it to a shop to be checked out. Any metallic sounds that you can hear at wot is not good.
Old January 21st, 2011, 08:06 PM   #3
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
It's highly unlikely that you are getting valve float. These cars really don't have that problem like a lot of old pushrod engines. Given your list of mods, detonation sounds a lot more like what you are looking at. You are probably going lean up top or just running too much boost and or timing for your setup.
You are making 410rwhp on stock heads, cams, exhaust (except for catback), and running on 91 octane? Have your tuner back the timing off or get a bigger pulley and run less boost. You are gonna pop that motor.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old January 21st, 2011, 08:09 PM   #4
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
What BOV are you running? The stock plastic Vortech POS?
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old January 21st, 2011, 08:49 PM   #5
J smitty is on a distinguished road
+1 to what tbird said. I heard that noise when I broke a piston ringland which is a cause of detonation! Take a look at the tune or just buy an IC or meth. injection to lower them IAT's!
Old January 21st, 2011, 09:11 PM   #6
2001 Bullitt
Yeah, I'm gonna stop with the WOT stuff until I get all this looked at, especially since this is my dd. Thanks for the info, guys.
Also, I've heard some mixed reviews about methanol kits
JBA welded in a more high-quality BOV near the T/B since they were still getting high pressure readings with that crappy Vortech one (which is still installed).
Old January 21st, 2011, 09:32 PM   #7
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
you might be getting detonation
check your plugs
410rwhp 520rwtq @ 12.9 psi
Old January 21st, 2011, 09:53 PM   #8
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
valve float is something i would look into if you are dropping boost in the higher rpm's. its not the likely thing, but is more possible than what i bout to mention. lifting a head would cause the same issue as well.
Old January 21st, 2011, 11:27 PM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
stock springs are good to about 15# of boost. i have seen people get closer to 18# before they float. it sounds more like det to me.
Old January 22nd, 2011, 12:06 AM   #10
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
check your plugs
What signs would a plug have if detonation were occurring?
Old January 22nd, 2011, 01:12 AM   #11
2001 Bullitt
Besides backing off the timing, should I also look at getting one step colder spark plugs, like the NGK TR-6's?
Old January 22nd, 2011, 01:25 AM   #12
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
your not running colder plugs already?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old January 22nd, 2011, 01:31 AM   #13
2001 Bullitt
No. I'm fairly new to this forced induction stuff. I bought the car at a dealership with the supercharger already installed thinking the original owner made sure everything was taken care of.
Old January 22nd, 2011, 02:13 AM   #14
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
I made 515rwhp with stock heads and valve train including valve springs. I had HP s292 cams and ran it to 6400 rpm. Never had any trouble with valve float.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old January 22nd, 2011, 06:08 AM   #15
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
YES, IMMEDIATELY!!!!
How many #s of boost were you running at that time, Jive?
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old January 22nd, 2011, 07:46 AM   #16
jivepepper's Avatar
Between 12-13 psi
Old January 22nd, 2011, 08:32 AM   #17
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
You have your blow off valve near the throttle body? Where is you MAF?
Intercooler? You didn't mention an intercooler. If I reading this right you have a stock motor, non-intercooled 11.5 psi supercharger, 410 rwhp, 91 octane gas, and you run it to 6400 rpms. Tbird's right. That motor is going to pop.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old January 22nd, 2011, 02:31 PM   #18
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
One step colder plugs.......for sure. Do it yesterday. The aftercooler should keep the ACT down plenty. But you definitely need to get a step colder plugs in there. When you take the stockers out, look at the ceramic portion under the strap for tiny pieces or "balls" of aluminum. You may not be able to see anything without holding a bright flashlight right up to them. They will almost sparkle with a bright light shined directly at them.
If that is your problem, you should notice an immediate disappearance of the symptoms. I would still verify exactly how much timing you are running on that engine under WOT and above 3k. You should not see more than 14-15 degrees of advance anywhere above 3,000rpm under WOT. AFR should be mid to high 11s
Old January 22nd, 2011, 03:15 PM   #19
2001 Bullitt
The MAF is before the blower. And I have Vortech's "aftercooler" setup. But I never run it up that high on the rpms, especially since I notice the metallic "pinging" right after 5k. That's just where JBA recorded my peak power. Either way, I'm laying off WOT and just gonna drive how I normally do, shifting between 2000-2500rpm until I get new plugs and the timing looked at.
Thanks, tbird. I really appreciate it
Old January 22nd, 2011, 03:17 PM   #20
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
No problem. Let us know how it goes
Threads Similar to: supercharged '01 Bullitt valve float?
Supercharged Bullitt - Stumbling/Mis-firing M3Killer 2005 - 2010 16 January 9th, 2011 02:10 PM
Bullitt Valve Cover Help S281 99-04 3 June 22nd, 2009 06:37 PM
My Bullitt #1696 Supercharged nd4spd 2005 - 2010 42 December 14th, 2008 04:29 PM
