12.35 @ 116
Flywheel choice for new setup..
So I'm going to be needing a new flywheel for my new shortblock (MMR 900), and that comes with an 8 bolt flywheel because of the Cobra crank. The clutch I will be getting will be a Spec Stage 2+. The only 8 bolt flywheels they make are for 99-00 GTs, 96-04 Cobras, and 03/04 Mach 1s. Are those flywheels the same size as my stock 6 bolt flywheel and will it work with my TR-3650?
Vortech boosted MMR900 and supporting mods 420rwhp 410rwtq loaded Mustang Dyno Turbo boost in progress |
Pick any 8 bolt flywheel (steel, aluminum). I like the SPEC personally. The flywheels are the same diameter between the 6 bolt and 8 bolt. The transmission has no impact on the flywheel choice.
12.35 @ 116
That's what I figured, but I wanted to make sure. Thanks! Reps!
NP, any time. Let us know what you make when you get it all put together.
12.35 @ 116
Won't be until late spring, but I'll be making a re-build thread soon!
I went with a stock ford nodular iron 8 bolt flywheel. I think it was about $90 from D&D.
Threads Similar to: Flywheel choice for new setup..
| Fuel pump setup for 500RWHP setup | bobz18711 | 99-04 | 34 | September 19th, 2010 11:52 PM |
| Clutch and Flywheel Setup | jake1191 | 99-04 | 11 | May 12th, 2010 02:30 PM |
| Classic body taillight setup vs. s197 setup | rockybalboa | Visual | 1 | May 22nd, 2008 12:08 PM |
| a choice | Modern_Muscle | 2005 - 2010 | 7 | June 9th, 2007 05:16 PM |
| cam choice... | 2ToneFox | 5.0 Mustangs | 4 | August 13th, 2006 01:46 PM |
