How many miles before its to late! - Page 2
Old January 24th, 2011, 07:44 AM   #21
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
You could also do a 3v swap to easily get to your horsepower goals. They were 300 hp from the factory as well. You use your stock exhaust, ECU, and wiring harness. You should be able to pick up a low mileage 3v at the junkyard fairly cheap. You then get the Logan Motorsport adapter and a Cobra throttle body and cable. You need to lock out the variable timing on the cam, and a few other small parts. There are a few threads on this swap as well.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old January 24th, 2011, 10:37 AM   #22
1999 Mustang GT
auto99gt is on a distinguished road
Definitely appreciate the info. I guess i have more options then i originally thought.
Will I need to beef up the mark VIII?
What about goin with a 100-150 shot of nitrous?
Old January 24th, 2011, 11:23 AM   #23
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
badass n/a motor + a blower cant go together. (im sure its been said already)
Badass n/a motor and nitrous go together like lamb and tuna fish!! And yes you will need to upgrade the internals if you are looking for real power. You will have to change the pistons anyway to get high compression for that "badass n/a" motor you are speaking of. forged internal, high compression n/a 4v motor plus nitrous is the way to go. Im running good power on my blower but if i could go back, id probably go n/a 5.4 4v motor with a 200-250 shot and BLOW AWAY my supercharged 4.6!!
but badass n/a motor and blower dont go together. I guess you could run maybe 5 pounds of boost. but that would be shitty to be limited to 5 psi. lol.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 24th, 2011, 11:47 AM   #24
1999 Mustang GT
Checked out the thread for the mark VIII swap. Seems straight forward, with a little fab and some extra parts for eve4ything to work right.
Old January 24th, 2011, 12:43 PM   #25
2001 Mustang GT
roybrown45 will become famous soon enough
it's what i plan on doing one of these days. from what i've heard the internals in the mark viii are the same as the 2v. to get more than 400ish out of it, you'd probably be best to upgrade.
Old January 26th, 2011, 01:54 PM   #26
1999 Mustang GT
What about a 200+ shot of nitrous?What about a 200What about holding up
Threads Similar to: How many miles before its to late!
A little late... but still New 1st_Time_Stanger New Members Introductions 4 February 1st, 2011 06:49 PM
little late but here goes Black02GT New Members Introductions 15 April 11th, 2009 11:30 PM
Its Late Im Up Chris'schick The Clubhouse 31 July 6th, 2008 02:32 AM
F**K its late DeMello The Clubhouse 2 June 17th, 2008 06:54 AM
90,000 miles is it to late? flattusmaximus78 V6 Mustangs 31 December 15th, 2006 08:43 PM
