1999 Mustang GT
How many miles before its to late!
Recently new member. I have a 99 gt w/ automatic trans. Just made it to 164,000 miles. My plans are to build a badass n/a engine, and eventually forced induction. Along with upgrades to suspension, brakes,etc.
I've learned thro other threads that i need to upgrade the internals and if I do internals, ill do cams and heads to match. It's starting to burn oil, so im wondering if now is the time I should rebuild, before it g9es to far? I also would appreciate some insight on my trans. Rebuild, upgrade( if any)? not sure what to do here. |
1998 Mustang Cobra
how is it burning oil, are you getting blue smoke and when and under what conditions, or are you frequently checking your oil and its disappearing faster than it should.
![]() " When in doubt, go flat out"- Colin McRae MM Cobra Club #76 MM Cleavage Club #14 285 CREW #8 |
2003 Mustang Gt
13.26@102.77
with that many miles shouldnt you just lean towards getting new shortblock that can hold more power? and you would need to build the bottom end for the power. i would also say work on the rear end and getting a stall
03 Termi Wheels with 315 nt555r's, 4.10 gears, sct tuner, Brenspeed Custom Tune, JLT True Cold Air Intake, Trickflow 75mm t/b and Plenum, Mac Longtube Headers, Mac o/r H pipe, Borla Stinger Catback, Steeda Lowering Springs, and Mach 1 Chin Spoiler. |
upgrading your internals has to do with building an enginge with forged steel parts because they are stronger. Forged crank and forged rods and so on
2003 mustang GT
Yeah, sounds like it is time to step into the performance spotlight... I would look into getting a racing block that will hold the ponies. Start from scratch and do it right, or if your on a budget... tear down your block and take it to a good machine shop and have it inspected so you can possibly bore it or something. as for the tranny, what I did is, went to a well known tranny shop and secretly asked a technician if he wanted to rebuild my tranny and put a shift kit in it at his house on the side for cash... he said he would as long as I drain and drop it out of the car and took it to him. Since he worked at the tranny shop he got a discount on parts. He was well knowledgeable and only charged me $250.00 to rebuild my C6 Trans... Clutches, bands, and all, including shift kit. It’s backed by a 302 with 351 heads pushing 350hp. I put a 2500 stall on it and have never had a problem with it... by the way I picked up the tyranny from a junkyard for $100.00 about 12 years ago...
I'm going On A Manhunt!
2002 true blue GT
speed of time @ 88mph
what kind of power are you looking for and whats your budget?
mac lt's, mac O/R H pipe, spintech super prostreets, JLT RAI, 14"antenna, mach 1 chin spoiler, two 12" kickers.
1999 Mustang GT
I've been told there's visible smoke when leaving a stop light. Just changed the oil yesterday, and it was low.
1999 Mustang GT
I'm lookin to break into 300hp range. Should stroke and compression be changed or not.
Already have 3.73s, want to upgrade diff and axles to 31 spline. |
1999 Mustang GT
Nile P. Pezdel of Pez Dispenser Inc. CCA
2001 Mustang GT Vert
Look into MMR, get a shortblock built. I'm in the same boat as you right now, so I started a savings account to put my extra pennies into; I'm looking at getting an MMR 900 stroker with a Boss mod block. My car has been sweating oil out the back of the engine for a while now, so I'm hoping that by the summer I can be replacing it. Good luck to you, though.
164k is a lot, good to know these things hold up fairly well. |
1999 Mustang GT
I've looked into MMR short blocks and long bl9cks. they tell you how much horesepower they can handle, but i have not found where it says how much they produce.
It's variable depending on you're options. A basic 900 shortblock is simply a regular 4.6 with forged parts, it won't make any extra power (it may make less due to excess weight of forged parts in the rotating assembly, but it'd be negligable). It's all about being strong enough for later stuff. A stroker is usually good for about 30 more hp though. Other than that, if you go for the long block you can get ported heads (or the trickflow heads) which would give you more power and a freer breathing car and cams which can be custom ground to your needs which will also give you an increase in power. Building a shortblock typically only nets you insurance that your car won't fall apart when you put more power into it.
thats because they are built to Handle power blower, nitrous, cams etc. they are built to handle power alot better than the stock motor. Its not an out of the box high hp race motor its and out of the box built motor for you to upgrade with less risk of blowing something like your rods and pistons.
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
1999 Mustang GT
That's what I was thinking. Same engine, just can handle more power.
I'm gonna look into an mmr block to fit my needs and budget. Check out some trans kits and from there. I read on one thread that you need lower compression for forced induction, but if I were to stay n/a, would higher compression be worth it? |
04 mustang gt
7.21 @ 98
if all your lookin for is numbers in the 3xx range then you can def. stay n/a and accomplish that. if you want 4xx then its forced induction time.
![]() cams + 150 shot |
If you want to be N/A, you basically need higher compression to make it worth it. You certainly will be able to break 300whp with stock compression, though. If you go 11:1 or something, don't think you can put a blower on later. It's monster N/A car or monster boost car, you can't really have both.
1999 Mustang GT
Thanks for the info
2001 Mustang GT
just find a lincoln mark viii and get the 4 valve out of it. they came with 300 crank hp, so it should be easier to get to 300rwhp than the 2 valve build. they can be found pretty cheap too.
Car is for sale: http://nashville.craigslist.org/cto/2510060805.html http://www.autotrader.com/fyc/vdp.js...id=AT-121bdd21
1999 Mustang GT
Is that swap involve a lot of changes or fab work?
2000 Ford Mustang GT
It's pretty close to a direct swap as you can get. There is a thread on here called something along the lines of "Infamous Mark VIII 4V swap" that has all the information you need for the swap.
Threads Similar to: How many miles before its to late!
| A little late... but still New | 1st_Time_Stanger | New Members Introductions | 4 | February 1st, 2011 06:49 PM |
| little late but here goes | Black02GT | New Members Introductions | 15 | April 11th, 2009 11:30 PM |
| Its Late Im Up | Chris'schick | The Clubhouse | 31 | July 6th, 2008 02:32 AM |
| F**K its late | DeMello | The Clubhouse | 2 | June 17th, 2008 06:54 AM |
| 90,000 miles is it to late? | flattusmaximus78 | V6 Mustangs | 31 | December 15th, 2006 08:43 PM |
