Went to the track! help me out please :)
Old January 23rd, 2011, 07:20 PM   #1
01MGGT has a spectacular aura about01MGGT has a spectacular aura about
So I finally took the car to the track My mods are a vortech v1 that makes 7.5-8 pounds of boost at sea level but only about 5 pounds even at this high elevation (4700 feet) CMS stage 1 na cams with stock springs. 75mm TB and plenum meth injection and flows. Tires and suspension are 555r's 305/35/18's with all stock suspension minus steeda sport springs. At the high eleveation with 27mph winds and 30% humidity and temps about 50-55 degrees I think my best was 14.032 at 104.91 mph. I can tell the elevation had a huge efect because last time at the track with horrible traction on stock tires I was around 110-112 mph on a bad tune with an afr of like 10.2 lol. Now the car is completely dyno tuned (was done at Dallas at pretty much sea level I guess) and numbers are in sig.
Now my question...After like 3 passes I mastered doing my burnout and getting the tires nice and sticky. Out of about 20 passes (wasn't a busy day) I missed 2nd once and was very consistent with my times minus taking passengers along on 6 runs but didn't effect me much. My problem was when the tires were nice and hot I would bog horrible on launch because of how well the tires gripped. This was at tire pressures between 20-22 psi. I didn't go any lower as it seemed it wasn't a good move if I was already bogging. I have a 2 step programmed in my tune at like 3k rpm. So I couldn't launch any harder than that and was forced to deal with the bogging! What should I do? Should I try and get someone to change the 2step in my sniper tune to a higher rpm? What rpm would be good? Or should I leave it alone and move to 3.73 gears?
I honestly think the gears will help a ton. The car really lacks low end power using these cams with stock gears. Any advice would be great.
375hp 380tq
Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper
vids
http://www.youtube.com/user/01mggt
Mineral Grey Club member #14
Military Crew E-4
Predator Crew Chief Holloman
Old January 23rd, 2011, 07:34 PM   #2
chiefsmustang20's Avatar
'02 VERT
13.08@106.11
chiefsmustang20 will become famous soon enough
definatly the elevation bro and gears ... lol you should have got the gears beside the meth just my opinion ...... get the gears done!!
CMS STAGE II
FRPP 4.10s
LTS, O/R H, FLOWMASTER WELD ONS
EDELBROCK INTAKE
MHS 6061 ELBOW
NX PLATE 100 SHOT
SCT X3
TUNED BY JOE MANSFIELD AT ABOVE AND BEYOND PERFORMANCE
Old January 23rd, 2011, 07:45 PM   #3
Yeah lol. My 60 ft times were around 2.3-2.4. And there was no spinning or any drama... the bogging just ruined the launch entirely!
375hp 380tq
vids
Military Crew E-4
Old January 23rd, 2011, 07:53 PM   #4
2001 Mustang GT
roybrown45 will become famous soon enough
i'd say get it retuned if you're gonna be at the higher elevation for an extended period of time.
Old January 23rd, 2011, 07:55 PM   #5
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
fix those gears man!
i used a quick elevation calculator and it still only translated to a 13.5 @ 108 which it should still be wayyyy better than that. high elevation tracks are just like mustang dyno's, heart breakers lol.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old January 23rd, 2011, 09:10 PM   #6
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
man you have your work cut out for you, but at least you got some runs in.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 23rd, 2011, 10:06 PM   #7
J smitty is on a distinguished road
Def. the gears I have a similar setup and my best was 13.6. Im considering 31 spline dif, axles, 373's and uca's and hoping to go alot faster in the spring
Old January 23rd, 2011, 10:28 PM   #8
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Honestlly, I dont think you should be running meth injection with 7-8psi.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old January 24th, 2011, 05:48 AM   #9
I will for sure get some gears and remove the step rev limiter.
375hp 380tq
vids
Military Crew E-4
Old January 24th, 2011, 05:49 AM   #10
I had to put on meth injection to keep IAT down. It was insane on a warm day not running it. The car was tuned with the meth by my tuner as well. I have no FMIC.
375hp 380tq
vids
Military Crew E-4
Old January 24th, 2011, 06:31 AM   #11
11.6@118
thereal2v2fear is on a distinguished road
get some better gears and some slicks and launch the beast at 5k
02' Mustang|MMR 4.75L 1000se|Vortech|pump gas|566rwph/511rwtrq.
Old January 24th, 2011, 07:27 AM   #12
XectriK's Avatar
2000 Ford Mustang GT
XectriK is just really niceXectriK is just really niceXectriK is just really niceXectriK is just really niceXectriK is just really nice
Did by chance you turn off your traction control?
Old January 24th, 2011, 10:11 AM   #13
2003 Terminator Cobra
11.58@118
napwrd2vgt03 is on a distinguished road
i agree with everyone so far. get some gears, launch that bad boy around 4500-5000 and you will see a good difference.
Previous Ride:
Fully built 03 mustang: gone but not forgotten.
New ride: 2003 Black Terminator Cobra.
501/505 on 17psi
Old January 24th, 2011, 10:14 AM   #14
Awesome gears it is...wish I could afford a new 31 spline diff! And as far as traction control it's disabled in my tune. Trying to decide if lower control arms are really needed at this stage in the game. I may wait and see how she launches at 4500 or so rpm.
375hp 380tq
vids
Military Crew E-4
Old January 24th, 2011, 11:23 AM   #15
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
I would get torque box reinforcer's ($50 for upper and lowers off E-Bay), build the rear with 3.73's THEN launch at about 4,500-5,500 RPM's
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old January 24th, 2011, 11:48 AM   #16
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Get rid of the 2 step. I don't know what the reasoning is for setting it a 3k. I've seen this on another car before too where it was set at 3k. If you're doing gears you're better off building the rearend at the same time. With 375rwhp a launch on a 18" rim a low profile drag radial that will hook is almost gauranteed to snap an axle. Do the lower control arms at the same time. I also have Steeda Sport Springs with MM HD lower control arms, and FRPP uppers. Ran a 1.77 60ft N/A on BFG drag radials. Haven't ran it with the blower yet.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old January 24th, 2011, 11:54 AM   #17
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
gears made a huge difference for me, really made the car feel alot better and run ALOT better times
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old January 24th, 2011, 05:02 PM   #18
11.6@118
look on ebay for 31 spline diffs out of a explorer it might just come with 3.73's. thats what i did and it was all 80 bucks.
Old January 24th, 2011, 05:10 PM   #19
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
If you have the MSD 2 step, would you wanna sell it?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 24th, 2011, 05:35 PM   #20
Don't have a msd 2 step. Was just in my tune. Sorry baker Good idea on looking for the explorer rear end. I may talk to you when I get some cash and make sure I am buying the right thing. What exactly do I need rear end wise to make sure I don't snap an axle 100 miles from home? I plan to run 18's with DRs for a while and buy drag stars or something down the road.
375hp 380tq
vids
Military Crew E-4
Threads Similar to: Went to the track! help me out please :)
MVP Track Time 2011 Midwest Track Dates Feffman Midwest 2 April 11th, 2011 12:15 PM
2009 Track Day Schedule - MVP Track Time Feffman Autocross 8 December 31st, 2009 10:58 AM
Well took the 89 to the track ryans88gt 5.0 Mustangs 20 May 20th, 2008 06:44 PM
New To Track Fastback91 Drag 31 February 24th, 2008 03:39 PM
going to the track Blk01ponyGT 99-04 4 January 28th, 2008 11:13 AM
