I got a brake problem!!!
Old January 24th, 2011, 06:17 PM   #1
Sheep
OutKast09's Avatar
13.324 @ 103.80
OutKast09 is on a distinguished road
iTrader: 7 reviews
Send a message via AIM to OutKast09 Send a message via MSN to OutKast09 Send a message via Yahoo to OutKast09
Got a Brake Problem!!!
so i put the steel braided line, caliper, and rotor on and bleed the brakes. well i decided i wanted to up it from dot 3 to dot 4 and i didnt want to mix them so i bleed the passenger side till it was empty then i put the dot 4 in and tried pumping and bleeding and i still havnt got any pressure.....wut the hell did i do?
looks nice tho
yes its raining outside and im freakin wet.
Mineral Gray Club Member #9
Old January 24th, 2011, 06:20 PM   #2
Sheep
OutKast09's Avatar
13.324 @ 103.80
iTrader: 7 reviews
sorry for the 2 posts blame my computer
Old January 24th, 2011, 06:32 PM   #3
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
You need to bleed the master cylinder. You can't let the master cylinder go empty when bleeding the brakes because it will suck air in. Bleed the master cylinder to regain pressure. Then bleed the passenger side, and then driver side. If you loose pressure again rebleed the master cylinder last and you should be good. That's how I did 4 years ago when I did my cobra front brakes and it has been fine.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old January 24th, 2011, 06:33 PM   #4
Sheep
OutKast09's Avatar
13.324 @ 103.80
iTrader: 7 reviews
and how do i bleed the master cylinder?
Old January 24th, 2011, 06:45 PM   #5
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
Did you put the bleeder cap back on? What about the cap for the brake fluid?
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old January 24th, 2011, 06:49 PM   #6
Sheep
OutKast09's Avatar
13.324 @ 103.80
iTrader: 7 reviews
yea. blown stang said i need to bleed the driver side then bleed the master brake cylinder and i should be fine but i have no idea how to do that
Old January 24th, 2011, 06:50 PM   #7
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
You start with the pass side caliper because its farthest from the master cylinder...
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old January 24th, 2011, 06:55 PM   #8
Sheep
OutKast09's Avatar
13.324 @ 103.80
iTrader: 7 reviews
i did that. wut i did was i emptied out the reservoir so i could put dot 4 in with out mixing the dot 3 and dot 4
Old January 24th, 2011, 07:03 PM   #9
PRODUCTIONMAN's Avatar
PRODUCTIONMAN is on a distinguished road
if you bleed any one of the four corners dry, you got a lot of air to get rid of and it is probably at all four corners. I've done a lot of brakes. Rule of thumb is start at the furthest from the master (passenger side rear), then do the driver side rear, then do the passenger side front, and finally the drivers side front. Be sure to keep checking the master as it will go empty on you if you don't and you'll get more air in, and always keep the cap on the master while bleeding. I doubt you'll need to bleed the master. You will need to go around several times, not just once at each wheel. I assume you have a helper, and one of you is pumping and holding the pedal down while the other temporarily opens then closes the bleeder. It's a lot easier if you get a power bleeder. I use one from Mighty Vac that you connect to an air compressor and then it sucks the fluid down to the bleeder and one person can do it without having to pump the pedal. Hope this helps.
Old January 24th, 2011, 07:16 PM   #10
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
Mixing it would not of hurt anything. Just would ended up with dot 3.5
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old January 24th, 2011, 07:30 PM   #11
Sheep
OutKast09's Avatar
13.324 @ 103.80
iTrader: 7 reviews
i figured it would have been find but my freakin helper kept buggin me like "i wouldnt mix it if i were you" and it was getting on my nerves i was like what ever and now im in this dumb situation.....
Old January 24th, 2011, 08:12 PM   #12
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Merged all your 1,983 threads on this
Old January 24th, 2011, 08:18 PM   #13
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
^ lolz
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old January 24th, 2011, 08:20 PM   #14
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
bleed the master cylander. if you look at it you will see 2 bleed nipples. after you bleed that you can then continue to bleed out the rest of the brakes
Old January 26th, 2011, 08:29 AM   #15
Sheep
OutKast09's Avatar
13.324 @ 103.80
iTrader: 7 reviews
thanks guys. I got all of the air out now.
Threads Similar to: I got a brake problem!!!
brake problem tutman900 5.0 Mustangs 7 January 10th, 2011 11:02 PM
Help!!! E Brake Problem 04stang123456789 V6 Mustangs 3 December 9th, 2010 01:31 AM
new brake rotors installed, equals new brake problem StutteringStang06 2005 - 2010 23 December 16th, 2009 06:58 PM
brake problem!!! 95BlackStang 94-95 8 January 30th, 2009 08:43 AM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
