2001 mustang bullitt
car dies when coming to a stop
it dies when i an stopping under breaking...it will happen in neutral or when its in gear if i am breaking hard enough..i also heard the idle the other day bouncing around a bit so i am going to clean the iac right now...i have heard of this problem happening to other people before but i never heard what it actually was? ill let u know what happens after i clean the iac...
i have to slow shift 3rd cause my synchro is bad so under slightly heavier breaking and d/sing into 3rd it dies alot if that helps
2001 Mustang GT
![]() iTrader: 2 reviews
mine does it too, sometimes in nuetral when I mash the brakes at a stop i can get the car to stall almost
i could see my idle drop before under the same circumstances and come back up, but now the car is actually dieing
2000 Ford Mustang GT
There are three things that can cause an engine to die. No Fuel, No Spark, No Air. So do your basic checks like spark plugs, air filter, fuel filter. Cleaning the IAC is probably where I would start too.
1999 3V GT/2007 GT D/D
corner carver
Does you lights dim or radio turn off suddenly when coming to a stop? Just a thought because it could be a bad alternator not fully charging your battery. That happened to me a while back. I recharged the battery and over the course of a month it was dead again and I found out it was the alternator. Sometimes my lights would just dim or radio would power off but the car would die coming to a stop as soon as the rpm's dropped to idle.
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
MM's king of Neon's
404 - car not found
17.81@87
Can't forget vacuum/exhaust leaks. That's how mine was when I bought it. You'd brake or slow it down and you'd just watch as your tach would drop until it sputtered and died, unless you rev'd it.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#9 | |
well it runs fine otherwise so i dont think spark plugs..fuel filter was just changed and it has a k&n filter...and this doesnt happen all the time if it makes any difference...i could be dosnwishifting around a turn at like 30mph into 3rd gear and it would die if i am braking i guess because i have to push it into 3rd so slowly...
2001 Mustang GT
More than likely the IAC is either dirty or bad....but could also be a faulty TPS...
Dan |
corner carver
Yah, mine would to for a while but eventualy it would be dead??? Just something to look out for just in case
cleaning the iac seems to have solved the problem
corner carver
Did it die every time or at odd times?
Nile P. Pezdel of Pez Dispenser Inc. CCA
2001 Mustang GT Vert
I had the same problem, cleaned my Maf, fixed it temporarily but it turned out to be my 5th cylinder coil. If it comes back, hopefully it'll throw a code.
2001 Mustang GT
Good, looks like you've found the culprit...I would keep an eye on it though, cause even after cleaning it could go bad on ya....glad you got it taken care of though...
Dan |
Threads Similar to: car dies when coming to a stop
| What is this country coming to? You cant stop the desecration of the flag? | 03_StangGuy | Politics | 31 | August 20th, 2010 01:41 PM |
| car stalls when coming to a stop | joseph296 | 5.0 Mustangs | 25 | October 20th, 2009 10:04 PM |
| My 2002 GT dies when rolling to a stop. | Willy Mo | Modular Mustangs | 50 | September 18th, 2008 12:10 PM |
| Car dies at stoplights/stop signs | Titmouse | New Members Introductions | 7 | November 30th, 2007 04:45 PM |
| Engine dies coming off hwy | frankyees | 99-04 | 11 | October 13th, 2007 01:52 AM |
