2002 mustang gt
![]() iTrader: 1 reviews
taking the axles out
Hey do you remove the c-clips that hold the axles in, I already removed the pin un the dif. Its giving me some problems, any input would be very helpful
Rock stock
Bringing Yellow Back
remove abs sensore that is buy the breaks, then the axles will slide far enough in
. use magnet to get the c clip out and bada bing the axle will slide out ( this is once you remove the center pin)
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
2002 mustang gt
Damn I never thought of doing that, thanks man! Reps to you
Rock stock
np thanks
i ran into the same problem you did
yeha like zinc said, the abs sensor has to be removed to push the axles in enough to remove the c-clips. Just be careful when removing the axles and reinstalling them. You can ruin the axle seals pretty easy. Just be gentle.
![]() Last edited by F8L GT; January 25th, 2011 at 06:07 PM. |
2002 mustang gt
The seals are the reason im removing them lol......what type of socket do you use for the abs sensor?
Rock stock
i think its a 8mm, and i used a wrench
be careful mpot to snap the bolt becasue it is very small
2002 mustang gt
I think its smaller but the bolt has a different head, I haven't seen it before
Rock stock
!FACEPLATED!
i went through and fixed all your miss spelled AXLES
sorry it was bugging me. Its not a 8 mm socket. It is a special socket that almost looks like a female torx bit
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
#10 | |
2002 mustang gt
but thanks that helps alot man
Rock stock
2002 mustang gt
Well I gott the axles out but now I need abs sensors haha
Rock stock
!FACEPLATED!
How soon are you putting it back together?
2002 mustang gt
I am working on it now, the flange to the pinion gear is being a bitch but im not doing bad for jack stands and now air tools
Rock stock
!FACEPLATED!
I was going to say, Mine will be coming out in a few weeks
2002 mustang gt
Yeah its not as difficult as everyone says its just a pain being on the floor in ohio weather. I can't wait until spring to drive her
Rock stock
!FACEPLATED!
i know the rear isnt difficult, Ive had mine out numerous times. I was talking about the ABS sensors incase you needed them
#17 | |
![]() and yes you need a special torx bit. it has a hole in teh center of it. kinda like a female torx bit
o shit sorry, been awhile since i took mine apart
may bad
I think it is called a safety torx...
^^ EDIT: Not the same.. a saftey torx is like a regular torx with a hole in it. Whats needed is a female torx.
![]() Last edited by Willy Mo; January 26th, 2011 at 02:00 PM. |
Threads Similar to: taking the axles out
| axles | Applehead281 | 99-04 | 13 | June 28th, 2010 01:37 AM |
| Hp and axles .?.?.? | Montanasvt | 4V / SVT | 30 | February 4th, 2008 11:46 PM |
| axles | GTsetGO | 99-04 | 7 | December 22nd, 2007 09:45 PM |
| Best Axles? | 01GT | 99-04 | 26 | June 6th, 2007 02:03 AM |
| 02 GT axles | DrHolliday | 99-04 | 1 | March 20th, 2007 05:29 PM |
