2003 Mustang GT
13.58@97.84
Seatbelt Hell Arghh!
I bought my car used, and every since I've had it the friggin seat belts have been driving me nuts.
Both the passenger side and the driver side will not retract, if for a miracle they do, when pulling the belt out to buckle up, they will get caught in the hanger because the belt is pinched or folding up on itself. Is this a common problem? Would replacing the belts and assemblies take care of it. I've tried having the belt in the seat guide and out and it doesn't make a friggin bit of difference. It's something that should be so simple yet is so damn frustrating! |
12.73@111.36
Yes, it is a very common problem. Yes, it is frustrating. You eventually get into the habit of pulling the seatbelt out so that it doesn't twist. When exiting the car, you also get into the habit of flipping the part of the seat belt that doesn't retract back inside the car before you close the door.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Sadly my mach1 did this from day one. It seems to be a problem that doesn't have a good solution.
2003 mach 1 12.7x @103 4600 stall, 4:30, slicks & skinnies, ALUM DS, VMP tune. 1996 ford thunderbird (13.02 @104) pi block, all the bolt ons minus cams, 3.73, 3800 stall. |
2001 GT
there was a recall on the retractors, other than that if it applies to you, there is a how-to thread on how to adjust the tension on the spring that forces the seatbelt to retract. use the search or look at my past threads I replied in, it was just this week I believe that someone posted the link in a thread I wrote in.
![]() Rollin on 335 Steamrollers. |
n/a
Very common problem on stangs. There was an article on this problem a few years back in a 'stang magazne (Not sure which one, it was a couple years ago) I had this problem on my '02 GT on both the driver and passenger side. I was told to take it to a Ford dealer, and they actually fixed both of them for me for free because they said it was a 'safety hazard' and it needed to be taken care of ASAP. They told me all Ford dealers should take care of this. Give it a try, and if they say no.. Then give 'em hell. They told me if it ever happened again, then just bring it back.
TRUE BLUE CREW MEMBER #4
#6 | |
2001 GT
there was a recall.
n/a
I only found a recall on Mustangs for the seatbelt retractor for 99-00. But yeah I hear ya, I have had friends with all years of 'stangs with this problem. But maybe there is an active recall on other years I didnt find.
1999-00 Mustang: Seatbelt retractor may have incorrectly formed pin shaft that could, in some circumstances, prevent seatbelt webbing from being extracted.
2003 Mustang GT
13.58@97.84
I've got to figure something out, it's so irritating. Mine is an 03' so I guess the dealer won't be of any assistance other than to try and rape me.
I will search for the thread discussed above for adjusting the tension, hopefully that will be good enough. Otherwise, I guess I will replace the units and see what that does. |
All Homo All The Time
2003 Mustang GT
Whatever you run plus 5 seconds
Just call the dealer...wont cost you a penny to ask.
BLACK STANG CREW MEMBER #30
#10 | |
01
2001 GT
#12 | |
n/a
Threads Similar to: Seatbelt Hell Arghh!
| Seatbelt Help please | GrayMatter | 99-04 | 7 | June 22nd, 2010 01:22 PM |
| Seatbelt | Codeman | V6 Mustangs | 8 | April 21st, 2009 11:23 AM |
| Seatbelt Woes. | RAGEman | 99-04 | 13 | December 7th, 2007 07:42 AM |
| seatbelt | Monster90 | 99-04 | 9 | October 14th, 2007 10:47 AM |
| ABS and seatbelt | Cricket | General Tech | 0 | April 23rd, 2006 11:57 AM |
