Shift kit - Page 2
Old January 27th, 2011, 09:33 AM   #21
Mustang_Girl_32's Avatar
2003 v6/2003 GT vert
Mustang_Girl_32 will become famous soon enough
iTrader: 11 reviews
So if I were to get this one which my brother is a mechanic and can do all the work for this, do I need anything else?
2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K
2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
Old January 27th, 2011, 10:36 AM   #22
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
I believe the transgo kit supplies the correct size drill bits, but you'll need a drill to use them. I'm assuming b/c your brother is a mechanic, he probably has one. You'll need new tranny fluid to fill it back up after changing it out. Dropping the valve body causes you to lose more fluid than just dropping the pan. I think I put like 7 or 8 quarts back in after the shift kit. I'd go ahead and put in a new tranny filter while your in there also. You don't need a lift, properly placed jackstands are fine to drop the valvebody. When you drop the pan, start by loosening the bolts in the rear of the pan first and work you way forwards in order to control the fluid coming out.
Most importantly, you need patience. There are a lot of things that go "boing" in a tranny. Take your time and do it right. I watched the installation video that came with the transgo kit multiple times before tackling the job myself, and I actually setup a TV in my garage with the video on pause as I progressed through the install.
After it's all said and done, I love the way my car shifts.
Old January 27th, 2011, 03:08 PM   #23
Cruzzer08's Avatar
04 GT vert
Cruzzer08 is on a distinguished road
Its my understanding that you should not do a shift kit without also installing a Tranny Cooler...
Shift kit?
Old January 27th, 2011, 04:06 PM   #24
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
A cooler is always a plus, but the stock cooler should suffice until you go to a higher stall converter.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old January 27th, 2011, 08:26 PM   #25
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
+1^ being that these trannys spend 90+% of their street time with the converter locked up in o/d, they run very cool on their own
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 27th, 2011, 09:06 PM   #26
ytngt has a spectacular aura aboutytngt has a spectacular aura about
The easiest thing to do is buy a handheld tuner form a good tuner. They will re-map the shift points and pressures in the toon. Even though this is less than ideal it works pretty well.
I had a 4r70w (auto) with j-mod (shift kit). It shifted hard and held up to much hp and abuse.
Old January 27th, 2011, 09:15 PM   #27
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
not only does turning up the pressure create heat, the higher the pressure, the more power it takes to turn the pump.
while a handheld tuner is quite helpfull to dial the trans in, it's a very poor substitute for a shift kit.
2012 300a GT auto
Old January 27th, 2011, 09:15 PM   #28
iTrader: 11 reviews
What cooler would I need to get or would I definitely be fine without?
Old January 27th, 2011, 09:18 PM   #29
n03stang's Avatar
2000 mustang GT
n03stang will become famous soon enough
I used the b&m super cooler. Works great haven't passed 120* all winter. B&M 70266 - B&M SuperCooler Oil Coolers - Overview - SummitRacing.com
Old January 27th, 2011, 11:57 PM   #30
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
You will be fine without one. Seriously. A shift kit will reduce time in shifts and actually create less heat when installed and working properly.
Old January 28th, 2011, 12:11 AM   #31
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
V8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of light
could you install at shift kit on your own at your house? or have someone else do it?
any good tutorials or write ups? (someone should do one if they do another car)
Old January 28th, 2011, 12:16 AM   #32
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
The HD-2 kit comes with detailed instructions as well as a pretty decent video. It's not a very hard job, but you will need to raise the vehicle enough to get under it and work somewhat comfortably.
Old January 28th, 2011, 12:30 AM   #33
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
+1^ the instructions are very clear, the video is no longer included with the kit though.
anyone installing one of these kits can feel free to pm me if they get stuck, I'll be glad to help them straighten things out.
2012 300a GT auto
Old January 28th, 2011, 02:18 AM   #34
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
thanks. plan on getting one of these and a bm hammer eventually
Old January 28th, 2011, 02:23 AM   #35
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
skip the shifter IMO, they kinda suck.
2012 300a GT auto
Old January 28th, 2011, 11:10 AM   #36
SLOW :(
ESABATM is on a distinguished road
JMOD hands down.
The JMOD is fairly simple as long as you have a proper torque wrench and right drill bits. I did my TBird back in the day myself. Done the accumulaters along with OD servo and diff EPC valve.
2000 GT Spring Edition
Damn money Pit
http://www.silverdollarraceway.com
Originally Posted by 01MGGT View Post
I am a 1/4mile guy so performance steering isn't really important.
Old January 28th, 2011, 01:18 PM   #37
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
are they still bad for just mostly street use?
Old January 28th, 2011, 11:30 PM   #38
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
no, you'll be fine if you just want looks.
2012 300a GT auto
Threads Similar to: Shift kit
new shift handle = new shift boot? ZenMGT 99-04 5 November 30th, 2010 01:11 PM
What rpm should i shift at? 93hatch 5.0 Mustangs 61 February 19th, 2009 12:33 AM
shift kit? 92hatchback 5.0 Mustangs 5 July 15th, 2008 02:38 PM
shift kit Black04Stang 99-04 16 July 8th, 2008 03:35 PM
Tuner..Shift Points and Shift Pressure..??! Cesar2cool 99-04 6 February 19th, 2008 12:44 PM
