Differential bearing grease?
Old January 26th, 2011, 06:50 PM   #1
Sfstanggt is on a distinguished road
I recently changed my entire rear end to 31 spline axles and all, but now i am getting some weird noise from the rear end. I am pretty sure it is the carrier bearings and want to know if the carrier bearings should be greased prior to installing and, if they do, what kind of grease should i use? I put some synthetic grease on the bearings prior to installing them, but I think i used the wrong grease. Any help is appreciated.
Old January 26th, 2011, 08:22 PM   #2
jk_aktion's Avatar
jk_aktion will become famous soon enough
don't worry about the grease, the diff fluid will keep everything lubed up. the noise you hear.. is it a whining noise? if so it will be your gears making the noise, that means your back lash is off. what brand of gears?
Old January 26th, 2011, 08:44 PM   #3
FRPP gears. I did not remove the pinion gear as I already had 373s installed. I just removed the carrier, swapped the ring gear, put the 31 spline axles in and shimed the new carrier the same as the 28 spline one. I used 75-140 diff fluid (debatable whether or not i should have used use 75-90). It's kind of a weird noise. Kind of a whine but nut really. I did not check the backlash cause I did not remove the pinion gear.
Old January 26th, 2011, 09:05 PM   #4
jk_aktion's Avatar
hmmm... my guess is the new carrier is slightly different size than the other one and might need more shims added to compensate.
Old January 26th, 2011, 09:17 PM   #5
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Even though you didnt change take the pinion out, you changed the carrier that the ring get was on when it was initially set up so you have to go back and redo everything as far as back lash and tooth patterns on the gears.
Old January 26th, 2011, 09:22 PM   #6
Banned from AFM member!
sillyrabbit0420's Avatar
1999 Mustang 2v 4.6L
sillyrabbit0420 will become famous soon enough
Not checking your backlash after you put it all back together is just asking for problems.
1999 2v 4.6L 380 RWHP/ 362 RWTQ, Tuned by Fastlane Motorsports
Peace - That brief, glorious moment in history when everyone's standing around reloading.
Old January 26th, 2011, 09:53 PM   #7
Ahhh.. Will do. I will open her back up and check the tooth pattern with some marking compound. Any better way to check the back lash without a dial caliper?? They are about $100 bucks for a one time use.....
Old January 26th, 2011, 10:45 PM   #8
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
You cannot mix and match ring and pinion gears without taking a gamble that it might be (probably will be) noisy, even if they are from the same manufacturer and machined one after the other. The final machining process is to create a "lapped" fit, which consists of mounting and running the gears on a specialised machine that uses abrasive lubricant to perfectly mate the gearset.
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old January 27th, 2011, 12:14 AM   #9
I am not mix matching ring and pinions. I Only upgraded to 31 spline axles. 3.73 ring and pinion are staying in the rear end just on a different carrier.
Old January 27th, 2011, 12:27 AM   #10
'00 V6 Procharged Mustang
mp4 player has a spectacular aura aboutmp4 player has a spectacular aura about
I bought one at harbor freight for like 8$ back when I needed one.
If you have a Oreillys nearby they should be able to rent you one for free as well.
It can be done by feel if you set up gears regularly but otherwise I'd stick to a dial gauge.
2000 Prochaged V6. T-lok, Mach 1 takeoff exhaust with H-pipe, 20% tint, OEM fogs and all HIDs.
SAE Corrected: 289HP/298TQ at 5100RPM(Pegged MAF).
Old January 27th, 2011, 12:42 AM   #11
cliffyk's Avatar
I misunderstood, sorry 'bout that--in that case then check the backlash as others have suggested, there should not be any other possibility for mis-alignment...
-cliff knight-
My Mustang
Old January 27th, 2011, 11:20 AM   #12
No problem. Thanks for the heads up though. Anyone know what kind of marking compound I should use on the gears when checking alignment? I used a cheap crappy one that came with the bearing kit.
Old January 27th, 2011, 11:35 AM   #13
cliffyk's Avatar
As much as it pains me to say this, try a GM dealer--p/n 1052351 Gear Marking Compound.
For some reason they tend to keep it in stock, while Ford dealers do not (Ford's is Motorcraft p/n XG-14)...
-cliff knight-
My Mustang
Old January 27th, 2011, 11:52 AM   #14
Thanks for the info man. Reps to you.
Threads Similar to: Differential bearing grease?
Little Bit of Elbow Grease and a Day Off wrr1020 99-04 17 November 4th, 2010 04:38 PM
Grease Fittings MustGT98allday 96-98 5 August 23rd, 2010 08:39 PM
Help! (Grease) dmachine22 99-04 2 May 4th, 2007 02:06 PM
5.0 after a lot of elbow grease dr.gonzo! Pictures 6 April 29th, 2007 02:44 PM
grease fitting holtte 99-04 2 December 18th, 2006 09:50 AM
