#21 |
I cant find the Victor Jr. fuel rails...........only ones i can find are on the edelbrock site and they have a damn Carb on top of the intake........
#22 |
![]() ![]() iTrader: 6 reviews
Yes. Patriots are overpriced garbage.
#23 | |
99 mustang gt
never @ 0
http://www.cjponyparts.com/product.a...paign=shopping
Ole Reliable
#24 |
Thats alot of money for only 550rwhp man.
#25 |
it will be able to go more of course. that 62mm is good up to 850hp which i probably ownt ever hit. i wanna build myself up like i said though. start out at like 400 after a few months go to 450, few more months or however long it takes to get used to it 100% and then go to 500 and just go and so on and so forth.
it might be alot of money but i love cars and to me its an investment in my own passion
#26 | |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
The Billet wheel over the cast. Billet is lighter(spool faster), much stronger(can spin faster), moves more air per psi over a cast wheel. Some people say the cast is better or the same as a cast wheel. but I like my billet turbo
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
#27 |
well shit if it comes down to it once i max out that turbo ill just get a bigger one if its that easy. i dont wanna go to big just cuz i dont see myself really getting into the 8 to 900 hp range. if it will do 600hp or 650hp i think it would be just fine with me.
ive heard nothing but good things about billet wheel turbos and the more i talk to people the more i realize almost everyone uses them and a few select people for whatever reason say cast is better cuz of some crazy observation. keep the advice coming lol before i deploy i want my list finalized and already partially purchased with some simple things i can get!!!!!!! |
#28 |
Resident Diabetic...
06' GT
13.829@103.49
![]() ![]() iTrader: 2 reviews
Subscribed! Good luck with the build!
2006 GT-3.55's, Pypes Muffler Delete, PIE Aux Port, GT500 Pedals, Hurst STS, GT500 LCA's, 55D rear springs, FRPP A arm brace, Diablo 93 Tune. ![]() motortalkblog.com |
#29 |
Nile P. Pezdel of Pez Dispenser Inc. CCA
2001 Mustang GT Vert
Someone mentioned that trickflows don't require notched pistons for cam selection, could someone clarify why?
#30 |
that is a good question!!! lol i heard that to just didnt think to ask.....I really am set on the MHS heads/cam combo they got goin on man its a freakin good deal and makes it really easy on me so i can concentrate on other stuff!
#31 |
trickflows dont require notcing really because the way the valves are you have so much PTV clearence...
and yea like scott said...a billet wheel is lighter and the way it is designed..you make more hp per psi and its just so much more efficiant... and with a turbonectics 62mm it will be maked out around 550-580 i would figure... everything looks good... no need for a viper spec if you only want 600hp...just find a cobra take out that has a 26spline input shaft in it already with the clutch,flywheel,and everything you will need... can be picked up for about 2200 bucks...
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
#32 | |
4v Know-it-all
Also, the last thing you want are wide lsa (114-118) cams and a single plane intake like the edelbrock, together they'll make horrible pre-boost power (driveability will suck). Stick with moderate duration, tight LSA and low intake LC cams, you will be much happier. Oh, and don't let anyone tell you that a tight LSA won't work with a turbo because the a/f will be blown out the exhaust during the overlap period. That's been proven wrong over and over because there is more pressure in the exhaust (between the valve and turbo) than in the intake. |
#34 | |
hahah sweet im gonna have to check that out as well. lol this could be alot cheaper build then i predicted it to be!!! only reason i wanted the viper spec is the of the .52 or .50 6th gear ratio to give me that really low 6th gear for trips home since i wont be flying anymore with the way TSA is handling pat downs. |
Threads Similar to: My Build Sheet (rough draft)
| Build Sheet | OHYELLER | 2005 - 2010 | 4 | January 24th, 2011 02:41 PM |
| Build sheet, give me feedback | beatup88lx | 5.0 Mustangs | 19 | May 10th, 2010 11:13 AM |
| NFL Draft | Vinyl66 | The Clubhouse | 2 | April 22nd, 2010 08:47 PM |
| Build Sheet | OHYELLER | 2005 - 2010 | 1 | June 16th, 2008 09:35 AM |
| Help Make Rough Draft Of Buildup?? | patshea098 | 2005 - 2010 | 13 | June 15th, 2007 10:00 PM |
