Tuning
Old January 26th, 2011, 09:07 PM   #1
Disturbin' The Peace
4.6DreameR's Avatar
2003 Mustang GT
4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light4.6DreameR is a glorious beacon of light
iTrader: 8 reviews
Tuning
I know that the handheld tuners do not give a lot of options for tuning but what is the best thing I could do on a Diablosport tuner? Advance timing how much? Richen or lean out the fuel, how much? Just a basic run down of the settings for the best performing 93 octane tune would be great.
2003 Mustang GT
STD 259rwhp 298rwtq
Originally Posted by L
In the 21st century, information is power, to where any human being can learn how to do anything with the touch of a button. With that the most powerful thing a person can do is share ideas and information.
Old January 27th, 2011, 12:22 PM   #2
Trick Tuners's Avatar
KB'd GT
My advice is not to mess with it. Just load the performance tune and use it as is.
Old January 27th, 2011, 12:29 PM   #3
SS Ball3r will become famous soon enough
the tuners are really meant to be used as a means to transfer a tune done on a computer into your ecu. Outside of the canned tunes built in, i don't think you can really effectively change much.
Old January 27th, 2011, 01:20 PM   #4
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
From what I've read, if you buy an SCT tuner, VMP racing sells their proracer software which gives you full access to all parameters that can be changed on a tune on a laptop. The tune can then be uploaded into your tuner and transfered into the car. Not sure if Diablo offers the same thing.
Old January 27th, 2011, 01:35 PM   #5
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
sell the diablo and get a sct and tune from Joe^^^^^ @ trick tuners
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old January 27th, 2011, 01:50 PM   #6
rodeheavers's Avatar
1981 4 EYED FREAK
9.48@147
rodeheavers is on a distinguished road
The parameters you can adjust almost make no difference at all with the diablo for some reason, I have had a few cars on the dyno and the customers wanted to play with that stuff and there was little to no power increase.
www.rodeheavershotrod.com
9.48@147 on pump gas through the
mufflers, still has pw,tilt,t-tops,all
lights, wipers!!!, check out the vid
http://www.youtube.com/watch?v=SloE3Zdetac
Old January 27th, 2011, 02:20 PM   #7
KB'd GT
I can custom tune diablo now too
Old January 27th, 2011, 05:31 PM   #8
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
If you're running high quality 93 octane, you can load the 93 octane tune and advance the timing almost all the way for a few more horses (that's directly from diablosport). If you do so, just make sure to listen to make sure there's no engine knock.
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old January 27th, 2011, 05:41 PM   #9
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
And if you do get knock toluene is 115 octane and is 10 bucks a gallon at the home depot. Rocket fuel. I advance the timing as far as I can and add 1/2 a gallon of toluene in half a tank of gas and that thing turns my 2v into a rocket
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old January 27th, 2011, 05:51 PM   #10
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
Turns your 93 octane pump gas into a whopping 94.5 octane 2v rocket fuel LOLs
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old January 27th, 2011, 05:58 PM   #11
Too Soon, Junior!
03 GT Vert
Lol from an engineering standpoint, bumping the octane rating of your fuel by a couple of points is a nice difference. The thing I'd be concerned about though is the toluene eating away at the fuel lines or even wearing out the fuel pump.
Old January 27th, 2011, 06:01 PM   #12
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
If you tune your car to take advantage of the bump in octane, it can be worth it.....but not just for a bump in octane. If you don't add timing for the extra octane, you can actually make less power
Old January 27th, 2011, 06:40 PM   #13
Too Soon, Junior!
03 GT Vert
Yup absolutely , higher octane fuel is more resistant to ignition, which actually hinders the combustion process in an engine if it's significantly higher than the recommended spec. I'm always having to explain this to people who run 93 lol
Old January 27th, 2011, 07:54 PM   #14
ytngt has a spectacular aura aboutytngt has a spectacular aura about
That is correct.
You can get SCT pro racer package software for $350 plus you need a hand held tuner. You get a base tune from VMP or whoever you purchase from. Plus you have the same software that your tuner has just in case you want or need to make a change. There are tuning books and a DVD out there in case you want to learn how to tune properly (lasorta DVD, SCT basics of tuning, Greg Banish books)
I highly recommend the pro racer package.
Advancing timing only makes more power until a point. Either power starts to drop or you detonate as you advance the timing to much. Advanced timing required higher octane. For racing purposes you can mix 93 and 110+ race fuel.
Regarding the OP, load the 93 octane tune and leave it alone. You should not need to adjust anything. Please do not blindly adjust a/f or timing without dataloging. You will need to know what your current timing and a/f is before making any adjustments.
Old January 27th, 2011, 08:00 PM   #15
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
FYI, Pro Racer does not give you full access to all the parameters unless you have "calibrator" level access to the software. Which means you have to be trained by SCT. But if you buy a tune from VMP there isn't a lot you are going to need to adjust anyway. Justin knows his stuff.
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old January 27th, 2011, 08:01 PM   #16
BWAL Is My Hero
JakeM's Avatar
This....
Old January 27th, 2011, 08:12 PM   #17
Yes that is true. These days SCT gives you everything a 99-04 GT will ever need in Advantage III. I have yet to need anything more.
Threads Similar to: Tuning
What is everyones opinion on tuning on dyno or street tuning CammedMysticCobra 4V / SVT 33 November 28th, 2009 10:27 PM
Do your own tuning. TROJENHORSE 99-04 11 August 13th, 2008 11:18 PM
Tuning bheet 2005 - 2010 2 November 20th, 2007 09:44 PM
Tuning... Baker02125 V6 Mustangs 5 November 19th, 2007 04:11 PM
Tuning gt_andy 99-04 6 November 3rd, 2007 04:40 PM
