SLP Linelock Install
Old January 28th, 2011, 03:30 PM   #1
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
If anyone has installed a linelock on their Mustang with the engine in place, how long did it take and do you have any suggestions.
The directions say to cut a few wrenches off to 3.5 inches long which I plan on doing, but other than that any suggestions that might speed the process up or make it easier to install.
Drive it like you stole it
Old January 28th, 2011, 04:31 PM   #2
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
I just put the SLP on my car a few weeks ago and man it works great! Your gonna need the line wrenches and the shortened wrenches it calls for, other than that its simple. It took me about 2hrs
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old January 28th, 2011, 04:34 PM   #3
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
Line wrenches will make it faster as well as shortened wrenches. Might want to go to your local parts store and pick up a set of cheap stubby wrenches or a cheap wrenches and cut them off. IIRC, there are only two sizes that are really needed.
Make sure to bleed the brakes afterwards.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old January 28th, 2011, 06:25 PM   #4
1999 GT 35th LE
I was planning on going to harbor frieght and buy the line wrench set and cut them to 3.5 like the directions call for.
I had used a crows foot before on my master cylinder lines when I took them loose to move the master cylinder out of the way for removing those damn BBK valve covers.
Old January 28th, 2011, 08:06 PM   #5
2004 Mustang
I didn't have anyone to help me with bleeding the brakes so I didn't bleed them. They were real squishy for about 5 miles then they came back to normal.
Old January 28th, 2011, 08:13 PM   #6
tbirdscwd's Avatar
12.88 @ 109.45 N/A
iTrader: -1 reviews
Bleeding brakes is like the only job on a car that you can literally enlist anyone with a partial brain or more to help you with. All they need to do is sit in the car and pump, pump, pump, hold, pump, pump!
Old January 28th, 2011, 08:23 PM   #7
2004 Mustang
Yeah yeah I know but I didn't have any help and I was ready to try it out
Threads Similar to: SLP Linelock Install
'92 T5 install into a '99 V6 6Stang99 5.0 Mustangs 1 August 17th, 2010 11:19 AM
Need help on an install MikeJones 99-04 8 January 16th, 2010 01:21 AM
SLP linelock sticking.... C MY 4D 4V / SVT 9 August 14th, 2009 09:41 AM
slp linelock tom2000r 99-04 22 January 30th, 2008 09:39 PM
