what next?
Currently have 04 Gt with CAI, 3.73 gears, Catless H Piper, Flowmaster 40's, Xcal tuner....I was wondering what would be the next mod...all recommendations are appreciated. I have a kenne bell 2.1 waiting to be installed and tuned in March by joe @ mustang magic. I was looking at getting a new clutch kit and cam across the term 10 spline and 26 spline anybody mind explaining the difference? I'm looking at getting some suspension work done along with a wideband A/F ratio gauge, oil pressure gauge, and fuel pressure gauge. Plan on just using the ride as daily driver and probably won't see much time at a track. have anywhere from $1200-$2000 to spend......
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
26spline is stronger. Maybe get the 26spline and a new clutch then put the rest away for a built block
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
Are you still running the stock clutch? If so, I wouldn't see it liking the amount of power you'll be at with a KB.
Yea running stock clutch....does the 2004 gt come with 10 spline or 26 spline? I'm looking at getting a built block around Oct while I'm away....are the most MMR 600 blocks plug n play or are modifications needed for it work?
12.85 @ 114
my stock TOB went out on my mustang the first time I took it to the track with the supercharger, and that was with fairly easy launching (and 2.3 60' times). I would defiantly upgrade your clutch, and possibly a set of cams to make it so you can keep your boost #'s down a bit until you can build your motor
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
12.73@111.36
If you intend to run a 26 spline clutch you are going to have to tear down your transmission and change out the input shaft.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
not intending to run a 26 spline clutch I was just kurious about what it was...thanks tho....
2003 Cobra
If you are gonna run the KB, you will need fuel system upgrades.
Whippled 03 Sonic Blue Terminator
