98 cobra motor in a 2000 gt?
I'm going to look at a 2000 mustang gt with a 98 cobra short block and 2v heads. The guy said that cuz of the heads on that block the compression is 11:1. The question that I have is that true? Thanks guys.
Moderator
2012 300a gt auto
12.10@116
yes, thats about right.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
that is correct on the cr. i would not buy it unless you have your heart set on sticking to a n/a car or nitrous car. the cobra sb is not any stronger than the stock gt motor so there is really no benifit to it other than a few extra ponys and maybe more head ach if he hacked the install up
#4 | |
The Mean Green
ok thanks guys. Due to the high comperssion would I have use premium gas?
#6 | |
2003 ford mustang gt
13.9 stock
, my car is tuned for 91 n paying 3.60 a gallon i dont drive it much
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
thanks again guys for all the information.
Ok one more question? With the compression that high, supercharging the car is completly out of the question? If I supercharge I'm only looking for about 385 to 400.
4500 but I can get for close to 3800
I hope I can get it for closer to 3800
2001 Mustang GT
blowing that car is a little out of the question, you would need constant meth or race gas, nitrous is a little unsafe at that level
1998 Mustang GT
1:34.43@13.86
not to act like a re-tard but compression has nothing to do with what octane gas you run... right? the main thing is that it throws off your timing instead.....
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
2003 mustang v6 ;)
slow
your right on that but with higher cr the timing will have to be dropped down so low it would serve no benifit to even having the higher cr in the first place. also boosting a high cr motor can be done and alot of people do it. the car will make more hp with lower boost with the higher cr. issue is the cylander temps get hotter so with fords crap .001 or less piston to wall clearence there is more risk of damaging a piston. personally i would still stay away from the car. the way i see it is the guy put in a used cobra bottom end to up the cr when there is so many better ways to gain 30 hp so i can assume the stock motor was toast.
Thanks once again guys. You guys are better the google or bing LOL.
Threads Similar to: 98 cobra motor in a 2000 gt?
| 1998 cobra svt motor in a 2000 v6 mustang | Fzshockey4 | V6 Mustangs | 3 | July 19th, 2010 04:39 PM |
| 2000 v6 motor change to explorer 4.0 motor | v6must742 | V6 Mustangs | 29 | May 25th, 2009 05:03 PM |
| will a 2000 motor fit in a 96 | 87gtmustang | 96-98 | 8 | April 28th, 2009 03:07 AM |
| 2000 motor in a 1997 gt? what do i need?. | Boostang | 96-98 | 2 | February 19th, 2009 08:21 PM |
| 99 4.6 cobra motor swap into a 2000 Gt | Cantbeatblack | 99-04 | 4 | August 6th, 2007 12:22 PM |
