Question about compression test
Old January 29th, 2011, 03:35 PM   #1
fmxona500's Avatar
1996 Mustang
I take myself way too seriously.
fmxona500 will become famous soon enough
Changed out my spark plugs, oil and uninstalled my vortech today (blew an oil seal), and noticed that I had a slight black crust (looks like carbon build up) on the base of my spark plugs and the ground strap. The plugs were dry past that.
I figure it's time to do a compression and leak down test since this motor gets driven pretty hard. I have 18CC Dished Manley pistons that have been bored over .020
What should I expect to see for numbers in the cylinders?
Old January 29th, 2011, 03:42 PM   #2
fmxona500's Avatar
1996 Mustang
Or should I call the engine builder on Monday and see what they say since some decking has been done.
Old January 29th, 2011, 03:48 PM   #3
ytngt has a spectacular aura aboutytngt has a spectacular aura about
Depends on many factors including cams, heads, static CR...
Old January 29th, 2011, 04:16 PM   #4
fmxona500's Avatar
1996 Mustang
Yeah I thought about that immediately after I posted. Heads had port work and over sized valves done as well as the block being punched to .020
I'm just going to call my builder in the morning and talk to him and see what he recommends.
Old January 30th, 2011, 05:15 AM   #5
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
if it was bored over that would raise compression to say 11.5:1?
"The only way to learn about a car truly is to break something and fix it yourself..."
Old January 30th, 2011, 05:23 AM   #6
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
consistant compression is the easy way to see if your motor is good. if all your cylanders are +-5 of each other i would call it good, unless your cr is under 140 than you may want to see if all your rings are smoked.
Old January 30th, 2011, 05:25 AM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
bore has little to do with cr. the compression ratio is affected by stroke, piston cc's, combustion chamber size, and head gasket thickness. decked heads/block also effect cr as well.
Old January 30th, 2011, 08:36 AM   #8
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Consistencey is your main concern. Anything around 140+ is decent on average
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old January 30th, 2011, 09:14 AM   #9
mach1soldier's Avatar
mach1soldier is on a distinguished road
It might not be the biggest concern but bore size will affect compression. The bigger the bore, the higher the compression.
To the OP. Consistency is what you are looking for more than anything. 5% is the standard accepted deviance.
2003 mach 1 12.7x @103 4600 stall, 4:30, slicks & skinnies, ALUM DS, VMP tune.
1996 ford thunderbird (13.02 @104) pi block, all the bolt ons minus cams, 3.73, 3800 stall.
Threads Similar to: Question about compression test
Compression test on FI jonnyspeed 99-04 1 December 8th, 2010 02:42 PM
Compression Test Stangin94GT 5.0 Mustangs 6 July 27th, 2010 12:01 AM
compression test hardhitter 99-04 81 July 9th, 2010 09:14 PM
Compression Test! 2003_GT 99-04 11 June 9th, 2010 11:58 PM
Compression Test...... UnixHH 99-04 38 January 25th, 2009 12:19 PM
