2000 GT Lightning Swap
Coolant Sensor Question
Just installed the 5.4 Lightning S/C motor in my 2000 GT. My coolant gauge isnt working? I had to run my cooling fan direct powered from fuse box cause coolant sensor is MIA. Someont told me I would have to install one on pass side. Anyone done this? If so where did you put it? How did you go about it.
theres two, one on the driver side head, half way back screwed into the head, and one should be in the manifold or cross over near the t-stat, it should be there, other wise youd have coolant leaking out of it, look for a sensor, two prongs, larger threaded base thats not plugged into anything
1998 Mustang GT
1:34.43@13.86
take a look:
![]() aw shit i forget what size to tap the hole, i know its metric though. i think the pitch is M8 x 3.5mm
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
NDFSPD he has a lighting motor, not quite the same intake you are posting a picture of lol
Yeah that is a 4.6 intake that ive seen used on the 5.4 swaps with adapter plates but thanks for posting the pic bro. I have a sensor on the pass side of my lightning manifold that is plugged into a sensor. Its right behind my fuel rail on the manifold? But its plugged in, may check to see if its getting power if not remove it and add an afermarket temp gauge in its place
Threads Similar to: Coolant Sensor Question
| Coolant sensor not coming up to temp | sniperd | 5.0 Mustangs | 5 | January 25th, 2011 06:21 AM |
| Coolant sensor bad? | freefallin2000 | 99-04 | 6 | September 1st, 2010 09:20 AM |
| PI SWAP coolant sensor | JK7208 | 96-98 | 5 | February 15th, 2010 06:01 PM |
| Coolant TEmp Sensor question | nHuman | 96-98 | 2 | August 19th, 2008 04:08 PM |
| coolant temp sensor question | nHuman | 99-04 | 3 | August 18th, 2008 02:30 PM |
