Taller tire?
Old January 29th, 2011, 10:38 PM   #1
therat1989 is an unknown quantity at this point
Question
Taller tire?
OK I have 3.73's and I love them except for one simple thing. Traction. My current tire setup consists of 255/45/17 Nitto 555's. I plan on running 275's on the rear next time but I am afraid that still will not be enough. I enjoy running from stoplight to stoplight and hope maybe a taller tire will help. In hind sight I wish I had gotten 3.55's but figured if I ever went to the track with DR's 3.73's would benefit me much more.
So here is my question. If I went to a 275/50/17 (if I can get this of course) how far off would my speedo be and how would it change my actual rear end ratio?
1/8mile 8.71@80mph on street tires.
Old January 29th, 2011, 10:44 PM   #2
hooliganryder's Avatar
00 mustang gt
hooliganryder is on a distinguished road
when i swaped tires i used my gps to figure my real speed..if u dont have one im sure u know someone who has one u can borrow.. there is also a calculater online somewhere that figures it for you
Cms stage 2 cams
04 explorer aluminum engine
spec 3 clutch
sct x3
k and n cai
410 gears
underdrive pulleys
roush short throw
Old January 29th, 2011, 10:44 PM   #3
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
the big problem you'll have there is extremely limited tire choice & the 28" tire height.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 29th, 2011, 11:21 PM   #4
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Get yourself a set of 15" wheels and run a tire that is 25.6" diameter and will have zero speedometer accuracy issues, provided that this is what you run now and have calibrated it already. If not, then get a tuner and do it up, homie
A 28" tall tire is freakin' big and all but guarantee you will rub somewhere, so prepare to roll some fenders if you do.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old January 29th, 2011, 11:24 PM   #5
I've looked it up and supposedly getting a wider tire changes your speeds as well. A 275 sized tire with a height of 50 bumps 1st gear up almost 3mph. That may not sound like much but 1st being bumped up that much should help with traction a good bit.
and @ jazzer. Eh I just want to be able to floor my car in 1st again. It always spins a little bit. When I had 3.27's I could dead hook in first. I don't think LCA's are going to help too much either. If I can dead hook in first again I will be happy.
Old January 29th, 2011, 11:28 PM   #6
Abyssinian of AX
'02 Saleen
19.34@42.259
A wider tire, in and of itself, will not effect the speedometer accuracy..... only the diameter. From personal experience, I found that a 1" taller tire will create a speed of approx. 5 mph slow reading at 70 mph.
There are scientific ways to calculate this, but just to give you an idea.
Jazzer
Old January 29th, 2011, 11:56 PM   #7
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
your problem isn't as much tire size as it is tire choice. something along the lines of a drag radial in 275/40-17 on a 9" wheel or better yet a 315/35-17 on a 10.5 might be more suitable.
there will come a point where nothing will help though, it's tough to hook a car up on the street.
2012 300a GT auto
Old January 30th, 2011, 01:30 AM   #8
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
+1 a wider tire will not affect anything as long as the side wall is the same. a 245/45, 275/40, and 315/35 all have the same sidewall, 110 mm.
I use the 1010 tire calculator to look at differences.
http://www.1010tires.com/tiresizecalculator.asp
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old January 30th, 2011, 05:42 AM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
op you just need new or better tires, you dont make the power to require much more than a good set of 245/45/17 dr's. getting wider heavier wheels will slow you down.
Old January 30th, 2011, 10:39 AM   #10
But as far as street tires go 555's are some of the best. I could pay a little more and some 555R's unless someone has a better tire in mind?
Old January 30th, 2011, 12:07 PM   #11
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Get some 555R's
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old January 30th, 2011, 12:17 PM   #12
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
I think you just need to look at different tires...
I run 4.10's with a 28" tire, and it took enough gear out to where I'm going to swap to 4.30's to get some of it back. With the 4.10's and 28" tire, the car isn't near as fast as it was with 26" tires off the bottle, but the increased sidewall gave me a ton more traction, so 4.30's it is.
You might as well go back to running stock 3.27 gears if you put 28" tires on a 3.73 car.
Bolt-On Bullitt... Unmodified longblock, stock intake and throttle body.
266rwhp/306rwtq
12.25@110.4 1.64 60ft
Currently Under Reconstruction
Old January 30th, 2011, 03:26 PM   #13
Didn't know it affected them that much. Oh well I have noticed today since it is warmer I hooked up just fine on the street. Maybe in the spring I can hook up every time. I know the colder temperature can affect traction.
Threads Similar to: Taller tire?
taller tire (abs light)...f8tl mrbigjeep 99-04 4 February 18th, 2010 09:25 PM
Taller Tire on Stock Rim? Shaun03GT 99-04 11 December 27th, 2009 08:33 PM
taller/wider tire john 99-04 4 December 10th, 2008 08:54 AM
How much taller is a 5.4 than a 4.6 futureMACH1racer 4V / SVT 39 July 21st, 2008 09:22 PM
Taller tire sizes? JAY'SRED02 99-04 3 August 21st, 2006 09:55 PM
