Forged pistons
I`m looking for Forged pistons Flat Top for my car ford mustang gt 2v I need it to fit with stock block stock connect road and stock crank.
My goal is Nitrous OR Blower.
2004 Ford mustang gt Diablosport Predator U7146 3.73 Ring Pinion Gears K&N Cold Air Intake BBK 78mm Throttle Intake Body BBK Underdrive Pulley Kit aluminum BBK long tube headers \ BBK Off-Road X pipe Cat-back Borla Stranger Steeda short shift |
if you are in there why not put a full rotating assembly so you can better take advantage of the power adder you choose. you can get a full rotating assembly for not much coin. No sense opening up an engine only to fix part of the weak spots.
2003 Mustang GT
Dont think i can help you regardless, but just for clarification to others, are looking for recommendations on which pistons to buy, or websites, ect.? Just some clarification.
Edit: 86er, why does your thing say your on probation? lol
because I didnt play nice with the mods, so they banned me for a week, now I have to watch my P's and Q's
ross, diamond, JE, Mahle just to name a few that will handle what you want to throw at them
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
Manley coated pistons are nice too
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
first decide if your going to throw boost at the car or run nitrous. flat tops with the valve notched is a great combo for running heads cams and nitrous. for a blower setup i would decide if you want to go with pd blower or centri. pd blowers like lower cr than centri blowers. also there is a big diff on how the piston to bore clearence is gapped for blower cars and nitrous cars. blower cars need looser rings and a larger .003-.0035 piston to wall gap to allow the piston to swell when it heats up.
2003 mustang v6 ;)
slow
i just looked over your post again and noticed you want to use the stock rods still. bad idea. both pistons and rods are crap in the 2v's so just a piston swap wont do you any good for making more power
Please I need the Part number of any piston will fit to my stock block and rods !!
#10 | |
and what else i have to change !!? and Which piston is the best for NOS.!!?
Is the Probe ( 10178-050 ) and I-Beam Rods Manley good for Vortech Or Nitrous !!?
2003 mustang v6 ;)
slow
you sound like a guy who is on a budget trying to build a pretty decent powered stang. first let me state again that building a motor is something you want to do once with no regrets. blowing motors always cost more in the end when a motor is not setup correctly. first there is a big diff between nitrous motors and motors built for boost. if your undecided on which power adder you want to go with i would stick with stock compression pistons which is -17 cc pistons. diamond and manley are my top 2 votes, next would be mod max for cost. the shop that is preping your motor is going to ask you what power adder your going to run and it is important you know 100% which way you want to go when your machining is being done. the reason for this is there are diff specs which your motor will be machined to. also it will require the piston rings to be filled diff with boost setups. i would advise again not to re-use your stock rods cause the best pistons and the best machine work will not allow you to push your power levels past what the stock ratings are. you can re-use your stock crank if your trying to save a buck but the thing that makes the stock crank weak is extra stress on the snout from a sc, high rpm's, and really hard launches. the weakness in the stock cast crank is due to its inability to flex unlike steal/forged cranks
2003 mustang v6 ;)
slow
http://www.modmaxracing.com/product_p/99025146.htm
this is a great budget set up. you can subtract the crank and re-use your stock one. and get everything you need for a decent rotating assembly for under 1000 dollars. this kit includes rings, bearings, and rod bolts. |
#14 | |
Ok, one more thing . What is the best Piston for the Vortech 2v KB Dished or Flat Top Piston !!??
2003 mustang v6 ;)
slow
for a centri blow setup i would run a -17 cc dish or even better a -18 cc dish. for kb blown car i would run it a little lower with a -19 cc dish
What about Nitrous 150 up to 180 Dose the Flat Top Piston Good or i better go for Dish ?
#17 | |
Resident Diabetic...
06' GT
13.829@103.49
Looks like a good set up though.
2006 GT-3.55's, Pypes Muffler Delete, PIE Aux Port, GT500 Pedals, Hurst STS, GT500 LCA's, 55D rear springs, FRPP A arm brace, Diablo 93 Tune. ![]() motortalkblog.com |
It is without the crank
2003 mustang v6 ;)
slow
Threads Similar to: Forged pistons
| forged pistons | 00GT | 5.0 Mustangs | 22 | April 11th, 2012 04:13 PM |
| forged pistons? | dkbanjo | 5.0 Mustangs | 9 | February 14th, 2010 07:48 PM |
| Forged pistons??? | SilverStang03 | 99-04 | 16 | April 28th, 2008 01:31 PM |
