Shift Kit, LCA's and Trans Cooler
Old January 30th, 2011, 02:04 PM   #1
JoshDrex00gt's Avatar
JoshDrex00gt will become famous soon enough
Wanting to order in the next couple of weeks depnding on how things go and wondering if i have the right Trans-Go Shift Kit picked out, there were 2 on summitracing which greatly varied in price
TransGo Performance AODE-HD2 - TransGo Performance Shift Kits - Overview - SummitRacing.com
the LCA's im waiting to hear how some custom one's work out, if not this is the item I've been recommended and am going with
View the 99-04 Mustang Rear Lower Control Arm Set at http://www.cheperformance.com
I have no clue on which trans cooler to go with, if anyone has a link I'd greatly appreciate it. I've decided to hold off on cam install & tune and decided to make the tranny better suited for the power, the converter is most likely going on at this same time. thanks auto experts
ll 2000 Mustang GT : On3 Powered ll
Old January 30th, 2011, 02:19 PM   #2
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Trans go will work. I would probably do Jmod though. The CHE control arms will work. Here is the cooler. B&M 70266 B&M SuperCooler Transmission Coolers Most i think use this one or a similar B&M one.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old January 30th, 2011, 02:37 PM   #3
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
I would recommend you purchase a different LCA
The 4-link suspension has enough bind already and best have at least one spherical bearing on any replacement LCA. This will add a bit more NVH, but will help to improve all aspects of rear suspension operation.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old January 30th, 2011, 02:47 PM   #4
im unfamiliar with a jmod and which lca's would you recommend jazzer
Old January 30th, 2011, 02:48 PM   #5
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
i'd go fairbanks no question imo
cams + 150 shot
Old January 30th, 2011, 02:57 PM   #6
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Fairbanks shift kit, Ford Racing Trans cooler, and Team Z LCA.
Old January 30th, 2011, 03:15 PM   #7
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
best to stay unfamiliar with the j-mod, just go with the trans-go kit.
as to the lowers, I'll have the info I mentioned early this week.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 30th, 2011, 03:16 PM   #8
thanks i'll do that and yes that's what i was awaiting lol
Old January 30th, 2011, 03:39 PM   #9
i'm wanting a simple quick street setup that will work if i can make it to the strip. improved launches are focus right now and making the trans operate more efficiantly and effectively. after that the cams will go in and more power, i decided there's no point in pushing the power up if i cannot effictively utilize it.
Old January 30th, 2011, 03:44 PM   #10
BYAHHHH!
2001 Mustang GT
13.874
Well this summer I will be putting on Baseline upper and lowers(both sphical ends) anti roll bar, subframe connectors. it's slightly over kill but I am trying to hook on the street as much as possible. I also have strange 10way shocks. 15in rim will help also. Weight tranfer is a big thing. A k member will help also.
I am looking for 410plus hp and 460plus rwtq if this helps
Old January 30th, 2011, 03:49 PM   #11
no it does im looking for 400whp also and trying to definately make mine like what you said. there are so many knowledgable people on here it just makes it confusing when they differ on opinions you know?
Old January 30th, 2011, 03:53 PM   #12
BYAHHHH!
2001 Mustang GT
13.874
mine wil be noicey as all hell lol but if I can hook on the street idc at all.
This will be my setup for the mid to high 600's hp too though
Old January 30th, 2011, 03:55 PM   #13
very true, launching hard is a huge plus if you can really make it move on the street you can catch people very off guard. nice man i'd love to see a 600whp on the street
Old January 30th, 2011, 03:59 PM   #14
BYAHHHH!
2001 Mustang GT
13.874
I talked to a guy with 758rwhp IIRC turbo stang that dead hooked on the street with a TH400(gm 3 speed auto). So I figure I can hook 700hp or less. Not that the car wont be capable of more
Old January 30th, 2011, 04:08 PM   #15
BYAHHHH!
2001 Mustang GT
13.874
Prolaunch #1 UCA kit, with #1 ARB-Poly(street use) & #1 LCA's. All for $675! Get some shocks and your good from there.
welded tq boxes, and such is a good idea too ofcourse
Old January 30th, 2011, 04:13 PM   #16
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
the main reason for such diffrent opinions is experiance.
best thing to start doing is when people try to give advice is to ask what thier set up is & what their car runs, if they cant answer, then move on.
2012 300a GT auto
Old January 30th, 2011, 04:48 PM   #17
blownstang's Avatar
J-mod vs Transgo - Modular Depot Forums
BC Automotive offers modified valvebodies: Valve body kits and components
Here is good info:
TCCoA Tech Articles
The Jmod:
TCCoA Tech Articles
TCCoA Tech Articles
I know of way more guys that run the Jmod and others who have switched from Trans Go to Jmod. Modified valvebody or Jmod would still be my choice.
Old January 30th, 2011, 05:11 PM   #18
thanks i appreciate everyone's advice and take all of it into my planning.
Old January 30th, 2011, 05:28 PM   #19
Here is good info:
TCCoA Tech Articles
The Jmod:
TCCoA Tech Articles
TCCoA Tech Articles
and thanks for the advice and part info man, do you or anyone else know what to expect for install on trans cooler & the jmod/valve body/shift kit?
Old January 30th, 2011, 06:46 PM   #20
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
installing a cooler is very straight forward, just pick a spot for the cooler it's self, remove the top cooler line at your radiator, run a line from the radiator to one side of the cooler, & a line back from the cooler to the factory line.
as to the shift kit, basically just drop the valve body & follow the directions in the kit.
to settle the j-mod vs. real shift kit debate for yourself, try to ride in a car that has a j-mod, then one that has a shift kit, I think the choice will be very clear to you then.
2012 300a GT auto
Threads Similar to: Shift Kit, LCA's and Trans Cooler
Trans cooler 100GT03 99-04 3 September 24th, 2010 04:05 AM
Trans Cooler WonfastGT 99-04 9 February 27th, 2010 10:58 AM
trans cooler Imran 99-04 17 November 6th, 2009 07:00 PM
best trans oil cooler unblock 99-04 3 December 3rd, 2008 06:49 PM
Trans cooler?? Shibby50 99-04 2 July 25th, 2008 04:17 AM
