2003 mustang GT
New cams, New problems
Just installed trick flow stage one cams, sounds good, runs well, but now I have OBD p1131 and p1151 codes coming up... Everything is good, no leaks, O2's still good, maybe need bigger injestors. I have 24lbs with bbk MAS cal. 24lbs. and long tubes with MIL's pluged to o2 sensors any thoughts? I think It may be something with my TB adjuster screw
12.85 @ 114
you need a tune before you start doing anything
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
i agree tune will help. on a side note how much did you gain from cams?
2003 mustang GT
ok, I was planning on having it dyno tuned, all ready have a tune for everything but the cams... My tuner guy told me It was 50/50 on if I needed to get it retuned... but I must say that I don't scare easy, but this car is insane now... It has like 3.23 gears, great for highway, never could really bust the backend loose from a dead stop, but now it peels out from 1st to half way through 2nd and its an auto
anytime you do a cam swap you need a dyno tune. the specs of a stock cam and a stage 1 are pretty different. so that makes ur air to fuel ratio off, which requires more than a canned tune loaded from a hand held tuner.. your injectors are fine tho, no need for new ones with a stage 1 cam
pretty sure the codes u mentioned are lean codes. ive pulled the p1151 a couple times on my car. a dyno tune will fix that right up. the p1131 has to do with the MAF, again probably reading lean.
![]() Stock Rear Springs FOR SALE! PM Me Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me |
2003 mustang GT
I'll probly get a tune after i get my nitrous kit so I can hit two birds with one stone
thatd b smart if its not ur DD. dyno tunes r spendyy
99 limited edition vert
For stage 1 cams you don't need a dyno tune, a e-mail tune will work great. A dyno tune can cost $700+ because you have to buy the handheld also. since you have to buy a handheld anyway, buy one with an e-mail tune(like from the tuner in my sig.) and when you get spray then take to dyno and should only cost $300 or so
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#9 | |
2000 mustang GT
12.7 109mph
dos trick flow make stage II cams?
2000 mustang GT
12.7 109mph
2003 mustang GT
No... I maybe a newbie to this forum, but I’m not when it comes to mechanics... I know the best bet to eliminate this problem is with a custom tune. Already have one for my setup without cams on my diablo sport handheld... It's obvious that with simple bolt on applications a custom E-mailed tune will work wonders, but when you start adding power adders such as forced induction (Nitrous included because it is a form of forced induction), and cams, the characteristics of the engine is changed dramatically... That said, the reason I posted this thread was to get insight on the trouble codes... everything is in working order with no leaks, it just runs lean on two different banks P1131 and P1151 which are codes reading from the left and right front o2 sensors, the real question at hand (which I should have been more direct), is, do I need bigger fuel injectors, or just a good tune? Right now I have 24LBS with a MAS to match, which should be more than enough. Just really looking to see if anyone else had the same problem with a stage one cam setup.
2003 mustang GT
you DO NOT NEED bigger injectors. maybe ur o2s are bad man just replace em. a failing sensor fails to relay info to the ecu which would make it run lean or rich whatever. so it maybe just be that your sensors are bad man
2003 mustang GT
really I think with the lift and duration of the cam, It makes my RPM's jump about 50-100 at idle so the computer is trying to over correct this problem back and forth making everything go to the lean side... just a thought, cause the stock cams are suppose to run smoother than what it is.. I'll tune it first and see whats up, cause the o2s are good, I know for a fact
2003 mustang GT
I'll just change them out to be on the safe side, after all they are fairly cheap... now that I think about it, it runs strong and rich at idle, but i just replaced the o2s a week ago.
when in doubt tune tha bitch out
well, I am forced induction with stage 3 cams and e-mailed tune (not canned!)and it runs great and makes awsum power, so take it for what it's worth.
Running a stage 1 cam is not that big of deal where you need bigger injectors or maf(not mas). most people I know have gotten away with not even a retune with stage 1's(comp 262's) who installed the cams and are they degree'd properly? usually LT's and o2 placement would be more of the issue
2003 mustang GT
12.85 @ 114
my car ran like shit until I had it tuned. Been there, done that. Trust me, tune it.
no tune: tune:
Threads Similar to: New cams, New problems
| problems after cams and head swap | 05gt4u | 2005 - 2010 | 23 | March 27th, 2010 12:41 PM |
| changing mach1 intake cams with 96-01 cobra cams?? | blue03mach1 | 4V / SVT | 19 | November 11th, 2009 02:11 PM |
| lunati cams vs. houston perf. vs. comp cams | mylilboostedpony | 99-04 | 0 | September 12th, 2009 06:05 PM |
