Clutch getting stiff
Old January 30th, 2011, 07:03 PM   #1
Maverick530's Avatar
2001 Mustang GT Vert
Average
Maverick530 will become famous soon enoughMaverick530 will become famous soon enough
Angry
okay well my clutch used to be really stiff... then the cable broke... ill post some pictures of that, it didnt snap, but its really messed up. so i replaced it with the only cable that i could find which was a zoom cable, now i replaced this cable less than a week ago, and it made the clutch so easy to push in it kind of scared me at first, but i got used to it, now its getting really really hard to push in, and im back to thinking theres something wrong....
i have a stage 3.2 clutch, is it normal for it to be pretty hard to push in, because it was a gradual change from soft to hard, but it is very noticeable how hard it is to push in.
the clutch is pretty new also, put in like 4-5 months ago.
Old January 30th, 2011, 07:35 PM   #2
jbodell11 is on a distinguished road
do you have a firewall adjuster and quadrant? i would only run a ford cable. seen aftermarket cables stretch. i would make sure the cable is adjusted properly before moving on to anything else
Old January 30th, 2011, 07:47 PM   #3
Average
i know that the engagement point is really high on it, so im going to need to go to the transmission and adjust it there some, but im just baffled that the cable is new and its getting so stiff, i have a 90 day warranty, but i dont know if they will just take it back and give my money back, i got it at advanced auto.
i kind of want a MM clutch cable, if i cant find a OEM one.
Old January 30th, 2011, 08:18 PM   #4
Average
This is my steeda cable with wires and coming out of it HAHA
Old January 30th, 2011, 10:00 PM   #5
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
stage 3.2 clutch? what clutch is it?
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Old January 31st, 2011, 12:52 AM   #6
Average
its a Fadanza,
but it was hard to push in then i changed my cable and it got very easy and smooth, then back to crappy.
Old January 31st, 2011, 12:57 AM   #7
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
If the clutch arm starts coming off the pivot ball it can cause the pedel to feel hard because it's a little off center.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old January 31st, 2011, 12:59 AM   #8
Average
will that be fixed when i go and readjust my clutch cable at the clutch fort?
because i need to go move the nut and the lock nut closer to the center of the bolt of the adjustable clutch cable... if that makes since.
Old January 31st, 2011, 01:20 AM   #9
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
little trick i do when i install new cables is spray some chain wax motor cycle cable lube down the cable to keep it nice and slick
Old January 31st, 2011, 01:21 AM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
another thing to check is to see if you have it routed correctly. some times after market cables get it real close to the exhaust manifolds and it melts it.
Old January 31st, 2011, 01:46 AM   #11
Average
i didnt really know how to route it, but i put it through the K member (i think thats what its called) and it goes on the drives side right next to the steering
Old January 31st, 2011, 02:51 PM   #12
Average
does anyone have a diagram or something that shows how to route the cable.
Old January 31st, 2011, 03:41 PM   #13
neverfastenough1's Avatar
Wow, thats not good. Anyways, I have the 2.1 and I can tell you it has been hard to push since I put it in. No problems with the cable yet, though. Been a few thousand miles already. I have the Steeda quadrant, adjustable cable and firewall adjuster kit. My Spec II was not that easy either, so I can imagine a 3.2 being a little harder. I have heard the stock cable is best.
Old January 31st, 2011, 11:41 PM   #14
Average
i wonder if its just the clutch cable settling in or someting.
Threads Similar to: Clutch getting stiff
Stiff clutch ocsailor86 96-98 2 December 28th, 2008 07:39 PM
clutch stiff every now and then.. soop7 V6 Mustangs 13 October 15th, 2008 12:23 AM
Stiff Clutch OcOnnor220 99-04 1 January 26th, 2008 04:23 PM
Stiff Clutch LUV2XLR8 2005 - 2010 15 December 22nd, 2007 02:41 PM
stiff clutch purplepony96 5.0 Mustangs 1 November 21st, 2006 05:00 PM
