T/A performance differential cover clearance
Old January 31st, 2011, 12:53 PM   #1
S281 is on a distinguished road
I have the regular low profile version of the T/A performance diff cover (4" depth) and not the new super low profile version (3.5" depth), i'm having my MM panhard bar installed and wondering if anybody has this combo and knows if the cover will clear the PHB with no issues.
2002 4.6L 5spd w/bolt ons
intercooled/Vortech V3 Si trim
Old January 31st, 2011, 01:12 PM   #2
2001 Bullitt
12.25@110.4
Bullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of lightBullitt5339 is a glorious beacon of light
When I had the PHB, I measured almost 4.5" clearance from the mounting surface to the PHB, because I had the exact same question posted here probably a year ago.
Bolt-On Bullitt... Unmodified longblock, stock intake and throttle body.
266rwhp/306rwtq
12.25@110.4 1.64 60ft
Currently Under Reconstruction
Old January 31st, 2011, 01:27 PM   #3
Damn that's gonna be a close call. Did it work out for you though with no issues?
Old January 31st, 2011, 01:31 PM   #4
2001 Bullitt
12.25@110.4
I never actually put it on before I took the panhard bar off and sold it. It didn't look like it was going to be a problem though. There's also some "wiggle room" when you install the PHB. You can get an extra 1/4" clearance with no problems during the install without affecting the geometry.
266rwhp/306rwtq
Threads Similar to: T/A performance differential cover clearance
GT40P heads 1.7 RR's Valve cover clearance Issues lakefrontlivin 94-95 8 May 28th, 2010 03:20 PM
GT40P heads 1.7 RR's Valve cover clearance Issues lakefrontlivin 5.0 Mustangs 7 May 17th, 2010 07:34 PM
Performance Differential Cover hits rear swaybar *HELP* PapaSmurf 99-04 5 December 9th, 2008 08:43 PM
New TFS Differential cover shurb125 5.0 Mustangs 16 March 27th, 2008 01:44 AM
