miss firing issue
i have a stock 2004 gt with 85,000 miles.i have only owened it a few days.it has a miss whenever its in a low rpm load or whenever i get bout half throttle.i have replaced all plugs and coil boots with no change.air filter is a little dirty but nothing major.service engine light is NOT on so scanner wont pick it up.any help would be great:
Try swapping some known good coils on one cylinder at a time and see if that helps.
A sticking EGR valve can cause this. My '03 started having those symptoms at 90k or so, I disabled the EGR in the tune and the problem went away.
This cost me about 1/3rd MPG as the EGR system does improve fuel economy at steady cruising speeds. This is not enough to cause me to buy a new EGR valve--someday when I get ambitious I will remove the valve and pipe and block it all off.
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
14.08@98
I had a similar problem at around 60k miles. My engine would missfire and sputter etc. making the car buck a little at low rpms. What I ended up doing was getting all my injectors flushed, replaced one, and also had a coil or two replaced. I guess theres a few things it could be, but yours may need something similar.
Built NA 2v with some goodies
i have been chasing this same problem down for the last couple days. but after reading a crap load of threads that just end, i got no where. so i figured i'd chime in now that i fixed my missing problem. turns out that the coils can actually be working, but be week. sure enough we tested them with a tool from my buddys shop. heres the link of the tool to better describe it Waekon 76562 Test Equipment - Electronic Testing
had to coils that were week, replaced them and it was running smooth. but the idle was low and would almost stall. changed the IAC and it was back to normal. plus the car had a lot more power. hope this helps. |
14.08@98
Goodluck bro, and yea for me once I swapped out some coils I was good to go.
its fixed.i bought 1 new coil and swapped one cylinder at a time and got it on 5th try.wow yaw was a huge help.thanx a million.now if i could just learn how to post pic of my car like yaw all got i would be set,lol
Threads Similar to: miss firing issue
| carbed H/C/I 302 miss/sputter below 2k, and miss at 5k+ | Silversixspeed | 5.0 Mustangs | 1 | August 13th, 2009 09:54 PM |
| M-16 firing | WilltheThrill | The Clubhouse | 9 | March 4th, 2008 12:24 AM |
| miss firing | the tick | 5.0 Mustangs | 5 | August 22nd, 2007 10:03 PM |
| firing | jonnotch | 5.0 Mustangs | 2 | June 4th, 2007 05:04 PM |
| miss firing | hopper | 5.0 Mustangs | 31 | May 30th, 2007 09:30 PM |
