Can Anyone Supply Info on Actual Flywheel Weight?
LinkBack (1) Thread Tools
Old January 31st, 2011, 07:15 PM   1 links from elsewhere to this Post. Click to view. #1
jonwrong's Avatar
2000 Mustang GT Super'ed
jonwrong will become famous soon enough
It's time to do a clutch swap (slipping). You can read stats of my car in my sig. I am thinking of going with the Spec Stage 2; feel free to weigh in on that.
BUT the main purpose of the thread is to find weights and opinions of actual flywheels for my 00 GT or other relevant years. I have not seen any good info after several our of cruising the forum, others, and google.
How much does the stock flywheel weight? How much does the fidanza alum weight? What about the spec steel and alum flywheels? ANY INFO on quality, etc.?
Saleen Series II 377whp/390wtq, Chicane I/C, Mosaleen Pulley, Fidanza FW, Spec Stage 2, Alum Driveshaft, BBK Headers, Steeda Exhaust, TruTrac 31 Spline, 3.55s, 315s, MM FLSCs, Rear LCAs, MGW Shifter, Eibach Pro, X2 Balljoints, Cobra Brakes, SS Lines.
Old January 31st, 2011, 07:42 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
alot more than an aluminum one. a lot of people like the ligher aluminum ones cause it reduces rotational mass and adds a little pep to the car. im not a fan of aluminum wheels cause they dont carry momentum very well on the track, but with a wot shift box i bet its a good combo with an aluminum wheel
Old January 31st, 2011, 07:47 PM   #3
MM Official Sammich Maker
roosgt!'s Avatar
1999 mustang gt
n/a
roosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really niceroosgt! is just really nice
i think the stock weighs around 25lbs and i know there's different weights to the fidanza but i think the alum is 8lbs.
KASE Racing
72 Chevell 500hp
74 Comet 500+hp and spray
99 Mustang GT bolt on's and 93 tune
85 Notch 520ci BBF
Old January 31st, 2011, 09:34 PM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
25-26lbs for stocker. aftermarkets are between 11-16lbs generally. if you arent pushing 400+ or always in high rpm's, then just keep a stock type flywheel.
Old January 31st, 2011, 11:53 PM   #5
jonwrong's Avatar
I of course no the reasoning behind a lightened flywheel.
I have read 25lbs for the stocker myself. I don't think any lightened mustang flywheel weighs 8lbs. Prob. 12 - 13 at the minimum.
Look in my sig bro; almost at 400whp for some time.
Old February 1st, 2011, 01:26 AM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
almost and over are 2 different things. i dont know what your future plans are with the car.
Old February 1st, 2011, 09:41 AM   #7
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
I weighed the OEM flywheel from my '03 GT, 26lb 3oz. I replaced it with a Ralco RZ Chromoly flywheel that weighs 16lb 9oz. The Ralco flywheels are not cheap ($244), however they are things of beauty all CNC machined from one-piece of 4140 Chromoly , precision balanced, and meeting SFI 1.1 specs.
They are tested to 12k rpm...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old February 1st, 2011, 03:26 PM   #8
roosgt!'s Avatar
1999 mustang gt
n/a
i was just figuring that the alum was 8lbs cause i bought a fidanza for my talon that was 8lbs but im sure the mustang's will be different.
KASE Racing
72 Chevell 500hp
85 Notch 520ci BBF
Old February 1st, 2011, 06:51 PM   #9
jonwrong's Avatar
That's not bad. The spec alum one is ~$300, and the fidanza is ~$350.
Old February 1st, 2011, 06:54 PM   #10
jonwrong's Avatar
I called spec and fidanza today.
Fidanza said their flywheel is 12.85 lbs; that's accurate enough to sound legit. The friction surface is replaceable, and there are no weights (I often read weight and balance horror stories) with respect to mod motors.
Spec said theirs is 14 lbs shipping weight, and the guy thinks it weight 1-2lbs less than that. I am thinking it probably weighs 13.5-14lbs.
I think I am going to use fidanza as I have heard good things with respect to lots of people I know first hand on various other rides. Seems that their products are consistently good.
Old February 1st, 2011, 07:13 PM   #11
cliffyk's Avatar
Is your car a DD or track only ride?
IMHO if track only then the AL wheel with the replaceable friction surface is the way to go, however if you drive it daily you may not like the "grabiness" and need to "drive it like you just stole it" feel of an AL flywheel with a steel/iron insert--and balance is an issue with all of them after you wear through the first insert--which was surfaced in place when originally manufactured. At each insert replacement you will nned pull the f/w and have it trued.
I am sure many will argue these points, however I have "been there and done that" once or twice (a man is supposed to learn from his mistakes) over the last 40+ years--which is why I choose the Ralco billet alloy steel unit for my DD...
-cliff knight-
My Mustang
Old February 1st, 2011, 07:56 PM   #12
jonwrong's Avatar
I had a heavily cammed turbo fwd sr20 with an 8lb flywheel. And it was sort of a handful to drive, especially when cold and from a start (more so when cold). I think the problem was most the cams, but the flywheel made it difficult as well. Honestly, it was not that bad, and if I still had the car, I would drive it all the time.
I DD the mustang as much as I can. But with two cars (the other one a tundra), I often go with the tundra when I know traffic will be especially bad or it's going to rain for sure. I like the driveability of the mustang as it sits, but I know I will regret not trying a lighter flywheel when everything is apart anyway. My only concern is that I know quicker shifts or better rev matching (throttle blip) is needed with the lighter flywheel, but T45s don't shift very quickly.
I am confident that I can live with whatever it will be like. I also used my old 8lb flywheel on a different car through two clutches without issue. I am still going to pull this whole thing apart this weekend, see what's in there, and make a final decision.
Old February 1st, 2011, 08:17 PM   #13
cliffyk's Avatar
Cool...
Sound's like you know where you are headed...
-cliff knight-
My Mustang
Old February 1st, 2011, 08:30 PM   #14
jonwrong's Avatar
BTW, I like that chromoly unit, but the wear surface won't' last as long as an alum with an iron insert. So I have mixed feelings about it. What experience has you had with it?
Old February 1st, 2011, 08:34 PM   #15
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i installed an xtd in a friends mach, i liked it. i have one for my car waiting to go in as well. i put a fidanza in another mach, it was a nice piece too.
Old February 1st, 2011, 08:46 PM   #16
cliffyk's Avatar
I disagree, Chromoly has at least the same, arguably higher, abrasion/wear resistance than iron--and even if it didn't I would not use an "insert" f/w on a DD; as I said above I have been there and done that, after the first insert wears things go downhill. Heat transfer between the insert and the f/w, and warping, is a big issue as I have never seen a new insert that "fit like a glove".
A good machine shop can make 'em fit properly--but that does add $$$.
Again, none of this matters on a track car where getting to the traps ASAP trumps all other considerations--but for a true DD that hits more than 8k to 10k/year think about it...
-cliff knight-
My Mustang
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/202180-can-anyone-supply-info-actual-flywheel-weight.html
Thread Can Anyone Supply Info on Actual Flywheel Weight? | Forums at Modded Mustangs | BoardReader This thread Refback August 15th, 2011 05:47 PM
Threads Similar to: Can Anyone Supply Info on Actual Flywheel Weight?
Flywheel Info Av8tor 5.0 Mustangs 8 November 23rd, 2010 12:21 AM
Flywheel weight Siegedg505 5.0 Mustangs 12 June 12th, 2010 09:04 AM
Info on SRA 8.8 weight BADASS03SVT Modular Mustangs 5 February 1st, 2010 09:20 AM
Flywheel Weight Blackblurr_00GT 99-04 9 January 5th, 2008 10:20 PM
Flywheel Info javier351lx 5.0 Mustangs 0 August 21st, 2007 09:26 PM
