4.6L Stroker
Old January 31st, 2011, 07:47 PM   #1
Fast02Pony's Avatar
Fast02Pony is on a distinguished road
4.6L Stroker
Hi, I'm looking to stroke my 4.6 to a 302, would it be a good idea to also bore the motor to a 302 also? Havent had ANY experience with stroker kits and have looked online the past three days for one but can't find any i can trust. Was wondering if i could get a little help here? Planning on putting cams, Patriot heads, and SLP Longtubes with an O/R X and SLP LM1's.
FRPP 4.10 gears, K&N Cold air Kit, Flowmaster weld in mufflers, TrickFlow Track Heat Intake Manifold.
Rear end is shot, getting Motive performance plus 3.73's, Ford 31 Spline diff. and Moser 31 spline forged steel axles.
Old January 31st, 2011, 07:50 PM   #2
MeanChad is on a distinguished road
Stroker kits are a waste in my opinion. If you are going to do some engine work get it ready for forced induction and some boost.
2003 Mustang GT:Blown and fully built
Old January 31st, 2011, 07:54 PM   #3
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
why did you post the same thread five times??
cams + 150 shot
Old January 31st, 2011, 07:55 PM   #4
12.84@108
04N20GT will become famous soon enough
It all depends on what you want out of the motor. The easiest way to make power on these motors is to put a blower on it. I have a stroker kit on mine but I have a lot more than just the added stroke too. You will see some hp gains but mostly more torque.
MMR 950 Stroker
TFS 38cc Heads
MHS TFS N/A stage 3.5 cams
11.5:1 compression
Nitrous Express wet kit
12.84@108 2.0 60' on motor. race weight was 3750lb
354whp 330wtq motor, 480whp 500wtq 150shot.
Proud Iraq and Afghanistan Vet
Old January 31st, 2011, 08:00 PM   #5
Fast02Pony's Avatar
Sorry, internet was being slow, didnt know if it had posted
Old January 31st, 2011, 08:07 PM   #6
86er's Avatar
do a big bore kit, either the FRPP block or sleeve your current block and punch it out from the 3.55 bore to 3.7 bore. Helps unshroud the valves, which is a gigantic help on these heads.
With stroker kits, the kits themselves wont make any power over a stock kit, its what you do with them that will determine it. The biggest gain is the under the curve power, not peak
Just a truck
Threads Similar to: 4.6L Stroker
Stroker Q! McMustang5.0 5.0 Mustangs 18 March 10th, 2010 01:08 PM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 10:46 AM
stroker? bigdaddy09 5.0 Mustangs 39 September 20th, 2007 06:06 PM
347 stroker 2007calispecial 5.0 Mustangs 8 July 31st, 2007 07:55 PM
