LinkBack (2) | Thread Tools |
#1
Rusty Filler neck with holes? JB weld it!
so i have pictures in the link below.
A few months ago; while going to put gas in,i hear it pouring out and i can smell it really strong. i look under my car,theres gas pouring out of the filler neck,i stop pumping go home,and come on here. Theres really no help as to what to do. So i took this into my own hands,i call a few junkyards, theres no chance of me getting one for a while and because 200 from the stealership just sucks! so i go to my local Advanced Auto Parts and see what they have, i find JB weld in "Industrial" tubes for 15 bucks,cant go wrong so i buy it. The upcoming saturday, i finally get to take a good look at it as its out.It's a mess,there appeared to be some epoxy putty wrapped around,which did hold for a while since my car was bought in may and it held till november so who knows how long before i bought it, it was on for; but a crack formed, so i ended up where i was. i crack all the epoxy putty off,and clean up the nice rusty neck with nice big holes with a wire wheel in a drill and wax and grease remover. then i get to work. i used some aluminum sheet metal and cut out a few pieces a little larger to cover the hole completely. i then formed the pieces with a ball peened hammer to match the curve of the neck.i mix up some JB weld and set in the the neck and let it start to get tacky then stick the pieces on there and throw more over the new pieces and proceeded to cover the entire neck with the jb weld to make a whole new neck basically. i let it cure overnight like it says 14 hours.sprayed over it with some black gloss enamel. and tada.it came out pretty nice if you ask me,and here i am a few months later and it is still good.so i have a new filler neck on hand in case it does start leaking again.but i don't see that happening anytime soon. I just figured id help those out there who are having the same problem as I, because i know this happens to almost everybody's stang. hope this helps someone!!! and for those in a real short time frame,you can use JB QWIK and get the same gas impermeable results.its a little bit weaker,but the neck doesn't have much stress on it. i would have used the JB QWIK the first time around. Filler neck 101 pictures by EddieJr93 - Photobucket Last edited by EddieJr93; February 2nd, 2011 at 05:57 PM. |
2003 MUSTANG GT
12.5@113
or.... you could buy a neck for 200 bucks...
sorry,not everyone is as fortunate as you.,,but like it says in the post, i do have a new one on hand but i didnt at the time,im just waiting for this one to break,if it even does.because it isnt gonna rust
1999 GT 35th LE
Yankee Ingenuity, in the south we call it something else, I won't say it but I'm sure you guys have probably heard it up north.
I would not want to be relying on that in my car, I would go search some junk yards or pay the stealership price.
![]() Drive it like you stole it |
i have one already lol,just waiting,before i was unemployed,now i can afford to lose the few ounces of gas,im just testing to see how long it works.once it starts leaking,then i will install the new one.plus its snowing like nuts up here,sothe salt wont rust the jb weld lol.this is one less winter for the new neck,the point of this post was not for hatred,it was to help out some people who may be in the situation i was in.
Good job repairing it. The aluminum and jb weld should do the trick.
im praying this isnt sarcasm! if it wasnt then thank you
No sarcasm intended, this time. I LOVE jb weld and the aluminum was a good idea!
2001 Mustang GT
![]() ![]() ![]() iTrader: 3 reviews
Great job man, I have the same problem I wonder how bad my neck looks!
![]() True Blue Crew Member #2 315's Crew Member (Dat azz) 255/298 Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club |
take a hard left turn and gas pours out lol, its not all that hard of a job.buy a new gasket too!
if ford didnt put convoluted tubing with ip ties around the filler necks,they wouldnt fill with sand and salt and then retain water and rust out the neck,i cut that crap off my new one already lol
thanks =D
2003 gt
5.4 32v on the way
Im not so sure id trust that jb weld for too long. A trick if anyone is interested, jb weld cures quicker with heat, but too much heat will make it runny. Also, you can get quick drying jb weld and its pretty much the same thing.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
bump lol
2004 4R75W Mustang GT
13.179 @ 104.30
+1, cut mine off a long time ago and painted it with black RustOleum paint, I remember when I cut it off a shit load of mud was in it and the filler tube was already starting to rust !
...Mods in garage
thanks for the +1 man!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
JB weld is the *racial slur* way of doing it!! Dont do that shit!!
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/202487-rusty-filler-neck-holes-jb-weld.html
| Thread Rusty fuel filler neck on 98, have some questions | Subaru Forester Owners Forum | BoardReader | This thread | Refback | September 18th, 2011 02:13 PM | |
| Yankee ingenuity | This thread | Refback | March 6th, 2011 09:57 PM | |
Threads Similar to: Rusty Filler neck with holes? JB weld it!
| Filler Neck Leak? | ltwells | General Tech | 2 | September 13th, 2010 12:53 PM |
| Gas filler neck problem | rxnodoze02 | 2005 - 2010 | 9 | April 29th, 2010 09:24 AM |
| broken filler neck | santanabori | V6 Mustangs | 1 | October 15th, 2009 11:21 PM |
| gas filler neck | DragonFreak | 96-98 | 5 | May 21st, 2007 09:25 PM |
