Never had this problem before :(
Old February 4th, 2011, 08:53 PM   #1
DarknessGT's Avatar
2001 Mustang GT
DarknessGT is on a distinguished road
Send a message via Skype™ to DarknessGT
Its raining cats and dogs here and i drove through a puddle i had no clue was there because the entire street looks the same. immediately making it out of the puddle my battery light came on and my power steering stopped working and my brake feel weird is fuck like my car isn't running when i try to stop. haven't had a chance to pop the hood because its raining so bad just wanted to get an idea of what might be going on. it also will hold a rev for longer now instead of dropping back down to idle. It starts right up but just will hold 1300 rpm for a little bit and then drop back down slowly..........poor car
Thanks Guys
BLACK STANG CREW MEMBER #YOUDONTSAYTHAT
Old February 4th, 2011, 08:56 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
probably sucked some water in the intake and messed your maf a bit. once it drieds it should be ok. another thing could be water on some of your electrical componants is messing with them.
Old February 4th, 2011, 08:57 PM   #3
2002 Ford Mustang GT
mutabi is on a distinguished road
Accessory belt slip off?
Old February 4th, 2011, 08:57 PM   #4
DarknessGT's Avatar
2001 Mustang GT
Sooo just let it dry???? I don't know shit about electricity.
Old February 4th, 2011, 08:59 PM   #5
DarknessGT's Avatar
2001 Mustang GT
could have sworn the alternator ran off the accessory belt???? if so my battery wouldn't stay charged when i start it if that was the case.
Old February 4th, 2011, 09:02 PM   #6
If the belt comes off, your battery wont charge (hence the battery light), your power steering pump wont be running, hence the lack of power steering. Not sure about the brakes. Different problem perhaps.
Shouldn't be hard to spot the problem once you pop the hood.
Old February 4th, 2011, 09:05 PM   #7
DarknessGT's Avatar
2001 Mustang GT
damn damn damn this sucks dick! FUCK YOU RAIN!
Old February 4th, 2011, 09:21 PM   #8
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Does sound like the accessory belt. Probably isn't off, just slipping from the water though. It also generally makes a nasty squealing noise, but that does happen.
Let it dry and you'll probably be fine.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 4th, 2011, 09:24 PM   #9
DarknessGT's Avatar
2001 Mustang GT
i hope so
Old February 4th, 2011, 09:42 PM   #10
rrborchard is on a distinguished road
check the belt
2000 GT - Vortech and some other mods...
Old February 4th, 2011, 09:57 PM   #11
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Your brakes run off of your power steering
its a hydro boost system
Your belt probobly got soaked and slipped causin it to slip on the alternator and the power steering pump.
410rwhp 520rwtq @ 12.9 psi
Old February 4th, 2011, 11:08 PM   #12
Better than Drugs!
mayosailor27's Avatar
97 Cobra makin' women wet
Decent @ A fast one
mayosailor27 will become famous soon enoughmayosailor27 will become famous soon enough
if your maf got wet by chance, pull it out with the star bit clean it with alcohol and q tips--be careful. Inspect your belt. Sometimes when it slips with some major water, it can become glazed and still slip. Just check it to be safe
96 GT-sold
98 GT-05 katrina victim-parted
90 GT-traded
98 GT-traded
98 GT-parted
94 GT/Cobra-sold
95 Cobra Saleened-sold
97 Cobra-knock -sold
99 GT-knock-sold
97 Cobra-sold
96 Cobra-nothing wrong but stock!
MM Cobra member 969
Old February 5th, 2011, 03:24 AM   #13
DarknessGT's Avatar
2001 Mustang GT
alrighty guys rain should stop sometime today will let ya know what it was thanks for the advice
Old February 5th, 2011, 03:43 AM   #14
Kevin C's Avatar
2001 Mustang GT
34.82 @ 21
Kevin C will become famous soon enoughKevin C will become famous soon enough
That's odd. It's probably a combination of wet belts, and water being sucked into the intake.
I hate driving in rain anyhow, and try to avoid it the best I can.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates
Vortech V1 sold
Old February 5th, 2011, 04:27 AM   #15
0949er's Avatar
12.85 @ 114
0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough
The lack of power sterring and brakes can all be explained by simply the engine shutting off.
OP the puddle was probably big enough to choke your engine. This would explain why the battery light came on. (this will also happen if you stall the car). I dout anything serious is wrong. If the car is running, I would let it run at operating temperature for about 5-10 min if you want to be really sure everything is out of your system.
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cam Stage 2's
+ more
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
C2H5OH on the horizon
Old February 5th, 2011, 10:15 AM   #16
mystk96's Avatar
2005 trd tacoma sport
mystk96 will become famous soon enough
my old gt started doing this when i did a battery relocate but it only happened for a few seconds then it was back to normal i always thought water got on the battery cable mounting point running to the starter.
never bothered me but in the rain
Old February 5th, 2011, 01:40 PM   #17
DarknessGT's Avatar
2001 Mustang GT
well my belts or belt i cant tell really because i had it open for maybe 1 seconds are completely off the pulleys lol i'm surprised my battery didn't kill itself but that is why everything is working so all should be good once it stops raining long enough to go out there and get it on.
Thanks for the advice guys btw where is the IAC, i am gonna take it off and clean it with alcohol and a q tip anyways just to have piece of mind.
Old February 5th, 2011, 11:53 PM   #18
mystk96's Avatar
darkness would you possibly like to just maybe trade your gt for my slobra
Old February 6th, 2011, 12:33 AM   #19
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
I was going to say the pulley probally slipped off. No big deal, could either just put it back on, or buy a new one.
Without the belt, the battery light will instantly come on. The belt drives the power steering which is a hydro boost setup, so it operates the brackets, the power steering etc.... Thats why you had shitty brakes, and no powersteering.
It wont drive the waterpump, so the car can overheat quick. So dont drive it like that.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Threads Similar to: Never had this problem before :(
misfire problem, probelms, probably a problem? rewadferger 96-98 5 September 13th, 2010 12:17 PM
just solved my evap problem now a more serious problem arises I NEED HELP please sj408 96-98 5 July 16th, 2010 08:12 PM
AC problem = Tune problem? SKRAPR 2005 - 2010 11 May 16th, 2009 12:29 AM
Transmission problem??? need help diagnosing the problem... Tmac3320 99-04 19 April 13th, 2009 12:58 AM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
