PICS:How do you remove the ABS pin?
Old February 5th, 2011, 06:18 PM   #1
All Homo All The Time
Nightmare69's Avatar
2003 Mustang GT
Whatever you run plus 5 seconds
Nightmare69 will become famous soon enoughNightmare69 will become famous soon enough
Im trying to take my rear axle out and cant get the ABS pin thingy out. I got the bolt out on the other side and tried to pry the housing loose but no luck. The passenger side someone rounded the fuckin bolt so Im going to have to cut and drill it out.
Is this a ABS pin? How do I remove it?
Here is the stripped bolt...
BLACK STANG CREW MEMBER #30
Old February 5th, 2011, 06:28 PM   #2
2003 Mustang GT
Im taking the 3rd member out to have my 3.73s installed.
Old February 5th, 2011, 06:32 PM   #3
dark star is on a distinguished road
Once you pull that bolt loose you should be able to tap out the sensor towards the middle of the car. Try gently hitting it with a hammer and punch or hitting the axle itself against the sensor
Old February 5th, 2011, 06:52 PM   #4
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
Stupid ABS sensors.. I bent one and my ABS don't work now.. But who needs that shit
Use a socket around the pin the tap it out.. <<< I did not do this
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old February 5th, 2011, 07:00 PM   #5
2003 Mustang GT
Ill give this a try tomorrow
Old February 5th, 2011, 07:56 PM   #6
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
When working on brakes/axles always buy a couple cans of brake cleaner and and a can of PB Blaster. Spray the bolts down with brake cleaner, then spray with PB Blaster and let it sit for about 30 minutes.
Drive it like you stole it
Old February 5th, 2011, 08:07 PM   #7
86er's Avatar
you prob used a regular 6 or 7mm on it? Most do it, but it takes an inverted torx to remove it properly. I just wiggle the sensor up and down and they always come out, at worst a rubber handle or something NOT metal to tap on it with to motivate it to come out
Just a truck
Old February 5th, 2011, 09:47 PM   #8
2003 Mustang GT
I sprayed all the bolts with PB blaster this morning
I got the other side out no problem. I just tap the metal pin and it came right out. The bolt on the passenger side is so rounded off now a 6mm is to big and a 5.5mm cant get enough bite. I tried pliers,pipe wrench,locking pliers,460 channel locks. I dont really know what to do now other than cut off the head and drill and use my easy out set.
Old February 5th, 2011, 10:01 PM   #9
2003 Mustang GT
I'm goin to try to hammer on a 5mm and see if that will hold on enough to break it loose. If that don't work and it probably wont,dremel tool.
Old February 5th, 2011, 10:07 PM   #10
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
just get the proper inverted torx socket, by the looks of the picture of the torn up one, the correct socket still may work.
SK Hand Tool SKT19761 13 PC Female E-Torx Socket Set
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old February 5th, 2011, 10:34 PM   #11
1 Wheel Peel
2000 Mustang 393w
Oh the one I bent was the one I beat the piss out of to get out... The one I used the normal deep wall socket for came out with no problem....
I do agree with 86er and Casper with the torx thought though
2001 GT Vert
2002 Six Banger
Old February 5th, 2011, 10:40 PM   #12
tp88's Avatar
2004 mustang gt
tp88 is on a distinguished road
i thought u didnt even have to remove the sensor to even remove your axles. i didnt when i did my gears..
Vortech Intercooled
hitech stage 2 cams
373 gear
75mm tb and c&l plenum
bbk l/t
410rwhp 390ft lb @7psi
image host
Old February 5th, 2011, 10:42 PM   #13
1 Wheel Peel
2000 Mustang 393w
Thats weird.... You should have to, to push the axle in towards the differential
2001 GT Vert
2002 Six Banger
Old February 5th, 2011, 11:20 PM   #14
carnut59's Avatar
2001 gt
carnut59 is on a distinguished road
the socket should be an E8.
Old February 6th, 2011, 03:00 PM   #15
I had to take them off to get to the c clips on the axles.
OP just grind or cut off the head on the bolt carefully pull off the sensor then the you should be able to grab whats left of the bolt with the vice grips and unscrew it. Or like you said drill it and use an easy out.
Old February 6th, 2011, 03:55 PM   #16
2003 Mustang GT
I had to cut the bolt and got the 3rd member out. Long story short I tried to drill the stud out and broke off one of my carbide easy out extractor in it. Im goin to have to see if the shop thats installing my gears can get it out. I dont have anything that can drill through it.
Old February 6th, 2011, 03:59 PM   #17
^ thats why I try not to use easy outs. Lol and if you do definitely buy a good set not a cheap set
Old February 6th, 2011, 04:03 PM   #18
2003 Mustang GT
I tried to drill out the extractor but I was doing more harm then good. Hopefully the shop can drill it out then Ill have to run a nut and bolt to hold the ABS sensor in place.
Heres the pics....
Old February 6th, 2011, 04:05 PM   #19
2003 Mustang GT
These were Craftsman easy outs.
Old February 6th, 2011, 04:35 PM   #20
^ thats the problem. I have had trouble with craftsman ones. Buy a good snapon/mac/matco etc set they are much better.
Threads Similar to: PICS:How do you remove the ABS pin?
anyone remove the abs from a 95 gt?? flamingvert1989 94-95 2 October 2nd, 2010 07:19 PM
Remove ABS?? 95project 94-95 2 July 1st, 2010 02:33 PM
How do I remove these? 93hatch 5.0 Mustangs 18 April 1st, 2010 12:20 PM
A/C - Remove or Fix sniperd 5.0 Mustangs 22 May 28th, 2009 12:34 AM
How to remove. stang94 94-95 2 March 18th, 2007 08:29 AM
