Discussing Clicking noise 01 cobra in the 99-04 Forum. Almost stock. The aluminum driveshaft that I have is the only thing that I haven'...
Old May 8th, 2006, 09:20 AM   #1
2001 Mustang Cobra
Almost stock. The aluminum driveshaft that I have is the only thing that I haven't removed to see if it is the noise culprit. I get almost a binding noise from the rear of the car that sounds mechanical. I am trying to find a stock driveshaft to swap for a test to see if maybe my aluminum one is bad, or at least the u joints. The shops I have taken it to cannot find the problem. They hear it but no one can find it. The shop that installed the shaft said they tightened every bolt under the car but we still can't find where the noise is coming from. I may remove the cat-back(stock) and see if that is the boner. Anyone had a similar experience? Help!
john
Old May 8th, 2006, 07:04 PM   #2
Casper98GT's Avatar
Hey man,
Only thing i have run into is: Some 1999-2003 Mustang Cobra vehicles may exhibit a "popping" type noise while turning into or out of an incline, such as turning into a driveway, at low speeds (below 15 mph (25 km/h). The steeper the incline the more noticeable the noise will be. This may be caused by the lateral movement of the stabilizer bar or one or more of the fasteners shown in Figures 1-3, that may not be tightened within the required torque specifications.
If you dont think that sounds like it, have you removed youre driveshaft yet to see if one of youre u-joints is binding up ? thats what i would do first. After that... i would put it on the lift and stand under while someone else drives the car so i can get a good idea where its comming from.
Casper
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old May 9th, 2006, 07:01 AM   #3
99mustang232's Avatar
1999 Ford Mustang V6
one of my friends with an 04 cobra had a popping noise similar to the listed tsb, and it was a broken oem weld
...even fire and single cammin
Old May 10th, 2006, 05:35 PM   #4
2001 Mustang Cobra
crap
I think my right rear poly bushing is in the wrong position. I am going to try to get a spring compressor and fix it. Somehow I don't think this is the complete answer. Swell.
Old May 10th, 2006, 08:31 PM   #5
2001 Mustang Cobra
weld
Which weld should I look at? I need to get this car tip to because my wife wants me to sell it soon.
Old May 10th, 2006, 08:35 PM   #6
his weld broke at the subframe
Threads Similar to: Clicking noise 01 cobra
Getting a clicking noise when i get on the gas Fox2102 V6 Mustangs 33 October 22nd, 2007 12:18 AM
Clicking .. Tapping Noise ... BlackStang V6 Mustangs 30 April 2nd, 2007 05:05 PM
rubbing and clicking noise Warlord Modular Mustangs 2 January 7th, 2007 01:47 PM
Quick Help (Clicking Noise) scubasteve041186 V6 Mustangs 9 November 2nd, 2006 04:37 PM
Light Clicking Or Knockng Noise - Help GTSilver 99-04 10 October 4th, 2006 12:02 AM
