After flashing a tune does your car take forever to relearn idle?
So next chance I get I need to flash a new tune to my ECU to change the 2 step rev limiter. But I dread a re flash because it seems the car takes forever to relearn the idle. I have had it take like 80 miles before. It's so damn annoying. The idle will be kind of high or it will hang a bit between shifts and other little things that make doing a relfash at the track pointless. Anyone else experience this? I am using a Sniper tuning system.
![]() 375hp 380tq Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper vids http://www.youtube.com/user/01mggt Mineral Grey Club member #14 Military Crew E-4 Predator Crew Chief Holloman |
I haven't ever used a tuner but I haven't heard of anyone having this problem before. (I could be completely wrong though lol)
SLP headers and Catted X, Magnaflow CB, Cobra Brakes, Drilled/Slotted 13" front and 11.5" rear rotors, MGW short-throw, aluminum intake manifold, cobra clutch, lowered, 3.73 gears, Steeds LCA's, FFRP UCA's, Steeda UDP's, Desencharger CAI |
2003 Mustang GT
8.26@83.06 (1/8)
I have an SCT SF3 and haven't had the problem. Where are you getting your tune from?
![]() SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering MM Bracket Racing Crew BAMA Performance Drag Team #1 Project Thread :: YouTube Channel |
06 mustang gt
Not the same year but mine does the same thing. If I reflash, it take forever to relearn. I dred going in heavy traffic after a reflash, it will stall sometimes and other times it will idle to high.
Bottle Fed
04 GT
![]() iTrader: 3 reviews
I dont think it has to do with your flash if it's idling high and/or sticking high in between shifts. trust me i've had the problem for the last 2 years. Before i got the tune it would do that, after the tune it was fine for about 30 mins worth of driving then it'd get outta wack again. every year i try to narrow it down and i just can't pinpoint it. Vaccum leak? IAC valve? Throttle position sensor? MAF? Sct flash tuner.. so far no luck, seems to be not as bad in colder weather though if that's any kind of clue ?
![]() If the Westboro Baptist Church is allowed to protest at funerals of slain soldiers than I think I will just have to back the @$$ end of my stang right up to their doors early on a Sunday morning and dump the freakin clutch...
It's for sure only after flashing a tune. I think it may do it after resetting ecu but can't remember. Once it does relearn idle it's perfect with no issues what so ever. No idea what causes it.
The problem is your tune. There are multiple variable and tables in the PCM that control idle. Then there is ISC Integrator value, over time it's value gets stored in KAM as an offset. This is what is taking the time to "relearn".
The fix is simple, get someone knowledgeable to fix your tune.
That happens to me as well. Anytime i change something via my Diablo tuner, it take a couple of days for the "hanging revs" to go away.
Threads Similar to: After flashing a tune does your car take forever to relearn idle?
| Forever Alone | dr.gonzo! | The Clubhouse | 21 | January 10th, 2011 10:06 PM |
| My new avi is forever | 93hatch | The Clubhouse | 47 | July 19th, 2008 08:35 PM |
| the debate can go on forever | 03BMstang | 99-04 | 9 | May 13th, 2008 10:02 AM |
| computer relearn | millivolt | 5.0 Mustangs | 4 | July 15th, 2007 03:50 AM |
| Goodbye Forever MM | Texan_Stud | V6 Mustangs | 28 | February 6th, 2007 01:06 PM |
