fuel injector help
Old February 7th, 2011, 09:12 AM   #1
ojb226's Avatar
n/a
ojb226 is on a distinguished road
Smile
fuel injector help
i am currently replacing the gasket on my intake manifold as i took out one of my fuel injectors, the red cap on the bottom of the injector came off as i pulled the injector out of the engine, leaving it stuck in the hole. not being able to see and pull it out of the hole using a flashlight and a grabber, i am worried/confused on what i should do next, does anyone have any advice? also, the reason behind the replacing of the gasket is that i am leaking coolant down each side of my tranny. the guy in the shop said that he has seen many 4.6 liters, around 100,000 miles start to leak coolant just like mine due to a bad gasket. has anyone else had this problem? advice is greatly appreciated.
i need a 99-04 tan leather driving seat! and tuner!
Old February 7th, 2011, 09:36 AM   #2
dark star is on a distinguished road
You have to pull off the intake manifold to replace the gaskets anyway. So after you get the manifold pulled off you should be able to stick a screwdriver or something in from the intake port and push out the injector cap.
Threads Similar to: fuel injector help
fuel injector help?? joedaddy4 5.0 Mustangs 12 May 2nd, 2009 05:06 PM
fuel injector ? 331n2o66stang 96-98 8 October 1st, 2007 08:44 PM
Lucas fuel injector cleaner and fuel filter Saleen0101 Modular Mustangs 0 September 25th, 2007 03:09 PM
Fuel Injector sizes without regulators or fuel pumps streetstang06 96-98 15 February 26th, 2006 10:02 PM
