airbags interchange 99-04 plugs diff between 99-01 02-04
Old February 7th, 2011, 11:16 AM   #1
jmoney2001 is on a distinguished road
hey guy just wanting to know if its ok to cut my airbag harness to fit my car. it appears that the 02-04 use a different harness and plugs. i got a set of airbags from a 99 and when i went to install, the plug in are different. so i was wondering if its ok to cut the plugs off my old airbag to splice into my new ones. would this cause any problems with resistance?
Old February 7th, 2011, 11:19 AM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Its your life man. Cut and splice your airbag if you want
410rwhp 520rwtq @ 12.9 psi
Old February 7th, 2011, 11:25 AM   #3
not the answer that i was looking for. how u figure that would b bad. every were it states that they do interchange from 99-04. no one has ever said anything about plugs being different. lots of people do airbag deletes iam not tryin to play with anyone's life iam just trying to make this work was i was told this would work
Old February 7th, 2011, 11:29 AM   #4
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
The way i could see it being bad is if that airbag dosnt work after you modify the wiring.
I mean by all means go for it. Its just not something i would do
Old February 7th, 2011, 11:39 AM   #5
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
Are the wire colors exactly the same? I'd be a bit hesitant to cut and splice airbag wires unless I could confirm with the vehicle wiring diagram that nothing changed besides the sockets.
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old February 7th, 2011, 11:56 AM   #6
haven't got that far. all i know is that i tried to install yesterday and seen that my airbag computer and airbags connector were different i was so pissed cuz i spent good money on them
Old February 7th, 2011, 12:07 PM   #7
emg22189's Avatar
04 Mustang GT
emg22189 is on a distinguished road
this.
Dude there are certain things you just shouldn't f*** with in a car, airbags being one of them. it's stupidity to risk your life to not just spend some extra money once. you could be paying for it for the rest of your life if something happens.
get the proper safety equipment for YOUR YEAR MAKE AND MODEL car, never try to modify something that isn't a direct match when it comes to safety equipment
04 GT
Intake, headers, Pypes Violator Catback with catted X, UDPs, 70 MM TB and plenum, steeda short throw, SCT tune, 4.10s.... more to come
Old February 7th, 2011, 12:12 PM   #8
emg22189's Avatar
04 Mustang GT
On a further note, even if the wiring is the same, i wouldn't exactly want a spliced wire powering something so important.
the wire could be spliced incorrectly or it could even vibrate loose with daily driving. and you won't know til you need the airbag.
04 GT
Old February 7th, 2011, 12:14 PM   #9
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
I mean if you wanna mess with a mini time bomb infront of your face go for it bro
Old February 7th, 2011, 12:14 PM   #10
well its either get it wired or no airbgs
Old February 7th, 2011, 12:32 PM   #11
Too Soon, Junior!
03 GT Vert
If I were in your position, I'd just check the vehicle wiring harness. Properly spliced wires won't vibrate loose. But make sure to disconnect the vehicle battery before installing them if you do choose to go that route
Old February 7th, 2011, 12:34 PM   #12
thank you bud. but what i am after is to see if someone has already done this
Old February 7th, 2011, 12:51 PM   #13
Too Soon, Junior!
03 GT Vert
I pulled the airbags in my Mustang since the airbags gave me a light concussion when I was involved in an accident with my Infiniti. But that's also due to my habit of sitting much closer to the steering wheel than most people of my size would. If you delete your airbags, the light will come on, but you can just pull the bulb from the cluster. What I need to do one of these days is disable the bulb out chime that goes off once in a while.
Threads Similar to: airbags interchange 99-04 plugs diff between 99-01 02-04
Hood interchange cedsks 99-04 4 August 12th, 2010 11:51 PM
interchange realrider88 99-04 4 April 18th, 2010 01:16 PM
Fox Seats Interchange dennislv 5.0 Mustangs 8 December 30th, 2009 12:12 PM
2 diff dynos 2 totally diff readings 03snakeminated 4V / SVT 45 December 4th, 2008 03:52 PM
3.8 parts will that interchange with 4.2L V-6???? ckracedesigns V6 Mustangs 20 April 23rd, 2007 09:29 PM
