Will a 2002 Gt Engine Directly Replace a 2000GT engine?
Looking at this engine was about to bid on it just wanted to see what if any alterations must be made to make this work on my car?
RIDE: 2000GT- MODS: 2007 3 VALVE ENGINE AND MORE...... |
I dunno, but I would think so.
unstoppable @ speed of light
Should be an exact fit, no issues at all.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the only differences should be if it was a romeo or windsor (wont matter since you will be replacing everything), and water pump set up.
Proud American
I believe that the 99-01s were windsor and the 02-04 are Romeo so that would be the only difference!
you will be able to swap engine
![]() 2000 ford mustang gt convertible 2004 ford lightning truck,,,,,sold 2001 ford mustang/cobra,,,,sold 2008 ford f-350 4x4 truck 1989 ford notch back 5.0 2006 custom build bobber |
RLY SRS
Easy Swap...
You wil have to run your MAF thouse because the 02+ have the IAT intergrated into the MAF... other then that it is a direct swap... |
#8 | |
2001 Mustang GT
Threads Similar to: Will a 2002 Gt Engine Directly Replace a 2000GT engine?
| 2002 GT VERT / 2003/04 MACH 1 Engine Swap | JBasco20 | Modular Mustangs | 5 | February 10th, 2011 11:23 PM |
| 302 in my 95 with V6 Replace Engine mounts? | dreamr | General Tech | 0 | October 30th, 2007 08:19 PM |
| How do I Replace the engine belt? | sammysilva | V6 Mustangs | 6 | August 10th, 2007 05:42 PM |
| 1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? | zygo4406 | 5.0 Mustangs | 10 | June 4th, 2007 06:53 AM |
| Engine specs 2002 GT | bittydrew | General Tech | 10 | January 26th, 2007 09:15 PM |
