coolant coming from radiator cap - Forums at Modded Mustangs
post #1 of 6 Old February 22nd, 2011, 02:50 PM Thread Starter
5.4mustang gt's Avatar
Exclamation coolant coming from radiator cap
having an issue with coolant coming out of my radiator cap but the car is not overheating. i kno its not the head gaskets cuz ive rebuilt the whole motor. i have no clue wat to think it is. ive replaced thermostat, the radiator cap, and water pump is not even a yr old. any suggestions?
5.4 SUPERCHARGED GT
5.4mustang gt is offline
post #2 of 6 Old February 22nd, 2011, 04:08 PM
i would only think that somehow you are getting air into the system, check the radiator fins, and heater core, make sure there isn't a small leak. also it really could be head gasket, compression check to be sure. other i would assume is the radiator cap not sealed but you stated it's been replaced. that's the only thing that i can think of right now.
jk_aktion is offline
post #3 of 6 Old February 22nd, 2011, 04:55 PM Thread Starter
ok thanks man ill check it out some more n try to find omething hopefully
5.4 SUPERCHARGED GT
post #4 of 6 Old February 22nd, 2011, 05:49 PM
do you have an overflow tank still? if so another assumption is you opened the tank cap while coolant was hot and in doing so it sucked in air causing air pockets to form in the heads and pushing coolant out of the coolant tank pressurized cap. if this is the problem i advise burping the coolant system.
post #5 of 6 Old February 22nd, 2011, 07:11 PM Thread Starter
ok um wats the best way to do burp it
5.4 SUPERCHARGED GT
post #6 of 6 Old February 22nd, 2011, 07:32 PM
86er's Avatar
park the car on a hill, nose higher than the trunk. Remove the radiator cap, let the car run
Just a truck
86er is offline
Human Verification
