Got a few codes i need help fixing guys :D
Old February 26th, 2011, 05:36 PM   #1
Maverick530's Avatar
2001 Mustang GT Vert
Average
Maverick530 will become famous soon enoughMaverick530 will become famous soon enough
okay well i scanned my car and got these codes
p0171 too lean bank 1
p0174
p0305 cylinder 5 missfire
and i think this is effecting some gas mileage so i want to fix this asap
anyone know what to do?
Old February 26th, 2011, 06:55 PM   #2
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
Possible causes and diagnostic aids here...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old February 26th, 2011, 07:06 PM   #3
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
fix the misfire code fist as that can cause other codes. i'd bet it's a coil going out, swap the number 5 and number 6 coils and see if the miss moves to cylinder 6. if so replace the coil.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old February 27th, 2011, 03:57 AM   #4
Average
it might move to six?
right now i put some seafoam into my tank first to see if its just a dirty injector but were do i get coil packs, i can only find like 8 together
Old February 27th, 2011, 12:40 PM   #5
11.85@116
you can buy them individually at a ford dealer or pretty much any parts store like autozone, oreily's, etc. any place should have a couple in stock.
what i meant by "move to 6" is that if the misfire on cylinder 5 is due to the coil, and you swap the coils between cylinder 5 and 6 so that the "bad" coil is on cylinder 6 now, then your misfire code will move to cylinder 6.
Old February 27th, 2011, 02:58 PM   #6
Average
oh okay. gotcha, i was in problem mode not problem solving mode, so i was thinking it might get worse lol
Old February 27th, 2011, 03:24 PM   #7
cliffyk's Avatar
Keep in mind also that misfire does not immediately mean an ignition problem. The misfire monitor measures and compares the rotational velocity and acceleration of the crank--that's all. It doesn't know whether it'a an ignition, fueling, or compression issue; just that the crank rotation wasn't right.
More about the misfire monitor here...
-cliff knight-
My Mustang
Old February 27th, 2011, 03:33 PM   #8
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
This. You first need to determine if it's fuel, spark, or compression (hopefully not compression). Sway plugs and/or COP to eliminate or determine spark.
Old February 27th, 2011, 03:37 PM   #9
11.85@116
^ totally agree with the above 2 posts. swapping coils is easy, it'll rule out that as a possibility or it'll confirm it as the problem, and coils going bad is the more common problem rather than a bad injector or burnt valve or something of that sort.
Old February 27th, 2011, 03:52 PM   #10
Average
well i have another engine a few miles away that i forgot about, and ill take the coils off of that one, and some fuel injectors and what ever i need i guess
Old February 27th, 2011, 04:03 PM   #11
86er's Avatar
how many miles are on your car? Do you have the cats? I had those codes and one other on an aviator, compression was good, new coil and a new plug, Still missing. Ended up being a clogged cat.
Im not saying thats the problem, just make sure you take it step by step and not over look anything
Just a truck
Old February 27th, 2011, 11:34 PM   #12
Average
i have a catted x pipe, and have around 95 thousand, i have all my cats, but as for the coil pack its going to be free, because of my extra motor, and if need be i can get a new fuel injector. right now im just put a bottle of sea foam into my tank and its running a lot better but im sure i still have the miss fire
Old February 28th, 2011, 12:24 AM   #13
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Could be the fuel rail pressure sensor. When mine went, I had 2 codes that popped up saying Lean in Bank 1 & 2. Can you view live data? using a scan tool or something?
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old February 28th, 2011, 01:16 AM   #14
Average
i think i can read live data. im useing a tool that hooks up to a laptop
Old February 28th, 2011, 01:27 AM   #15
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
If so check your fuel rail pressure. See if its all over the place. When mine went out, it would go from 45 to 36 to 41 to 45psi etc... When I fixed it, it would read 38-40psi at idle.
Also check your short term fuel trims just to get an idea of how lean its running.
Old March 1st, 2011, 03:01 PM   #16
Average
mmm kay, ive got three coils packs from the other gt engine (its at my dads shop and he took them off) but i dont know how to change them so this is going to be a learning experience one is a newer oem one from the looks of it, but is missing the cover to the two silver prongs and the other two ones i have are dirty but seem to be motorcraft.
Old March 1st, 2011, 05:43 PM   #17
11.85@116
they're a sinch to change especially on cyl 5 which is the front drivers side. all you do is unplug the connector, and then there's a 7mm bolt you have to take out which is clearly visible, then just pull it off like you would a plug wire.
Old March 1st, 2011, 06:45 PM   #18
Average
okay i did the change, and holy shit its so much better. when it idols it feels like my car is just turned off (its so smooth) and now i can accelerate from 40mph in 5th gear without my car jumping and running rough
Old March 1st, 2011, 08:21 PM   #19
Average
One more problem, my car seems to run rich even though it says lean, and if it idols for too long it runs like it's the car from hell, it bucks and sounds aweful I guess it's flooding the Rpms goes down to like 500
Old March 2nd, 2011, 01:45 AM   #20
Average
grrr is still throwing out the miss fire codes, but it feels so much better....
Threads Similar to: Got a few codes i need help fixing guys :D
fixing the outside of my car... trueblue02GT 99-04 27 March 25th, 2011 09:30 PM
Help fixing A/C OFM 96-98 7 June 16th, 2010 07:12 PM
PS3 Guys In Here Now - M.A.G. Beta codes! Safi The Clubhouse 47 December 10th, 2009 12:32 PM
Error Codes. (need help-computer guys) Dansby The Clubhouse 4 October 7th, 2008 09:06 PM
fixing a/c help AndrewA. All Other Vehicles 1 September 14th, 2007 06:17 PM
