P0193 fuel pressure at 90 PSI
LinkBack (1) Thread Tools
Old February 27th, 2011, 09:32 AM   1 links from elsewhere to this Post. Click to view. #1
ddaniels750's Avatar
2003 Mustang GT
13.2@107
ddaniels750 is on a distinguished road
Well I recently purchased an 03 GT and had to iron out a few issues. One of them being a code for the FRPS. I can't seem to get this code to go away. I've replaced the FRPS,CCRM,FPDM, replaced all vacuum lines and checked for any loose connections at the ecu. When I hook up the Diablo Sport the FP reads 90 PSI no matter what and it constantly gets 5.00 volts(which would explain the 90 PSI) Has anyone else ever had this problem? I'm leaning towards the ECM being at fault. It seems that someone replaced the original one with one from 2002 Mustang GT 5 speed.
Any help would be GREATLY appreciated.
Thanks!
Old February 27th, 2011, 09:41 AM   #2
torkum's Avatar
torkum is on a distinguished road
A bad fuel pump can also cause this code. Do make sure you have checked all the wiring for rubs around the engine.
Old February 27th, 2011, 11:28 AM   #3
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
did you check the fuel pressure with a manual gauge?
depending on wether you have 90psi or your ecm is reading 90psi is two completely different things. if your ecm is reading 90psi but your actuall rail pressure is normal then i would look into a wire rubbed through somwhere or some corrosion in a connector. i wouldnt necessarilly jump to ecm replacment
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old February 27th, 2011, 01:04 PM   #4
2003 Mustang GT
13.2@107
Very good question. Sorry I forgot to mention that the pressure at the rail is reading 39-40 psi. The Diablo is actually reading 90. I will have to go through and check the wiring more thoroughly.
I have also replaced the pump along with both internal filters as well as the external. The car had been sitting for some time and the fuel was somewhat dirty in the bottom of the sending unit. I have since run through almost 3 tanks of fuel and fuel system cleaner.
Old February 27th, 2011, 01:36 PM   #5
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
From a mechanical engineer in the automotive industry-
Sensors are typically designed to operate in the range of 0.5-4.5 V in range. That way, if the ECM sees below 0.5V or above 4.5V you should get a "failed high/low out of range" code. If it's below, it's probably grounding somewhere, and if it's high, it's shorting to source voltage somewhere.
In this case, it's failing high out of range, meaning it isn't a physical sensor problem, rather an electrical. If you've replaced the sensor I'd look for a short or mis-connection somewhere, likely to source voltage.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old February 27th, 2011, 02:15 PM   #6
2003 Mustang GT
13.2@107
That's definitely some excellent advice. I was also under the impression that it shouldn't read above 4.5 volts. It caught me by surprise to see a 5 volt reading. Does anyone have an ECM pinout diagram for 03 GT?! My next step is to check continuity between the sensor and ECM. On another note... I just pulled the connector off the FRPS with the key on and it still reads 5 volts?! This has to be a wiring issue.
Old February 27th, 2011, 06:35 PM   #7
MM's king of Neon's
404 - car not found
17.81@87
That absolutely indicates a short to supply voltage. Somewhere in the wiring your sensor signal is shorting to a supply voltage. You might have to do some wire tracing.
Wish I could help you out with the wiring diagram.
Old February 27th, 2011, 06:43 PM   #8
FoxHoss's Avatar
02' GT
i have diagrams im just having trouble posting them
Old February 27th, 2011, 07:20 PM   #9
FoxHoss's Avatar
02' GT
here ya go. i think i got it.
Old February 28th, 2011, 06:59 AM   #10
2003 Mustang GT
13.2@107
Very nice. Thanks! I'll be chasing down dome electrical gremlins tonight.
Old February 28th, 2011, 07:27 AM   #11
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
Here are the output voltages for the FRP sensor, and connector info:
VRef should be 4.0V to 6.0V KOEO...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old February 28th, 2011, 10:41 AM   #12
2003 Mustang GT
13.2@107
Thanks guys! I really Think this will take care of the problem. I'll keep you posted for anyone that may have a similar issue.
Old March 1st, 2011, 07:45 PM   #13
2003 Mustang GT
13.2@107
Well guys, I finally found the problem today and it turned out to be a problem in the engine harness. Specifically where it connects to the sub-harness that passes through the firewall into the ECM on the passenger side firewall. It seems as though someone was in a hurry and bolted the harness down and in the process they pinched two of the pins together in one pin socket. Therefore causing the brown/white vref wire to receive 5 volts at all times causing the FPRS to see 90 PSI.
Thanks again for all of your help.
Here's a picture of the harness... The second row up from the bottom, left side, third pin from the left.
http://s1119.photobucket.com/albums/...ls750/Mustang/
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/206087-p0193-fuel-pressure-90-psi.html
Saints Row: The Third Acheivments Microsoft Xbox 360 Acheivment Lists & Guides This thread Refback January 15th, 2012 01:32 PM
Threads Similar to: P0193 fuel pressure at 90 PSI
P0193 has car running crappy... BakerFX4 99-04 24 January 30th, 2010 04:57 PM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 11:41 AM
Fuel Injectors/fuel pressure 00silvergt 99-04 4 August 2nd, 2007 09:54 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
