2001 Mustang GT Vert
Average
antifreeze in spark plug ?
well i have a misfire code in cylinder 5 so i was changing out the coil, and when i pulled it out it was wet. and so i tryed pulling the spark plug, and there was yellow liquid... what do i do?
Blown head gasket, 1st choice. Hair line crack in head/block, 2nd choice. Did you over heat the motor? What does your oil look like?
Phil PRB Machining, LLC http://www.prbmachining-absdeletemanifolds.com/ 2003 Mach 1 NX 175 shot 10.73 @ 128.63 (Oct 2007) factory motor |
Average
i havent overheated it
1999 GT 35th LE
Was the antifreeze on top of the plug before you pulled it out?
It could just be the manifold is cracked and leaking, or the manifold gasket is leaking. Also before you take a spark plug out you should always use an air compressor and blow out the sparkplug cavity. Even with the coil boot sand and debris can get down inside there, and when you remove the spark plug it can fall into the cylinder.
![]() Drive it like you stole it |
Did you check your oil? Does it look milky white? Pull your oil dip stick and pull your oil fill cam cover cap to check.
Average
i didnt pull the spark plug yet
#8 | |
1993 lx 351 coupe
![]() iTrader: 1 reviews
+1 since its the boot that is wet, i would agree with this guy^ what year was your car again? the 99-00 are real bad about doing this, ford even had a recall on them. Mine did the same thing so I upgraded to the newer intake with the metal cross over.
![]() Killer Performance |
If you did not pull the spark plug and your COP had coolant, then the coolant came from an external source. And what do you mean you tried pulling the spark plug???
1999 GT 35th LE
Check the other coils next to the #5 and see if they are wet.
Blow the anitfreeze out of the cavity, put the coil back on and start the engine and let it idle to operating temp while you watch for leaks. I would say it's the manifold gasket or cracked manifold leaking antifreeze.
Average
Average
![]() this is the dip stick... it looks like oil? |
2001 Mustang GT
There's no way for that coolant to get on TOP of your plug unless it came from somewhere outside. It's not a head gasket.
Take everyone's advice ... clean it up. Warm the motor up ... and look around for a pooling up of coolant on top of the manifold. P.S. These motors rarely have YELLOW coolant. More like rusty brown creek water unless it's been regularly changed!
2001 Mustang GT [518 WHP, 502 WTQ][P1SC + 10psi][MMR900][Trick Flow Heads/Intake][Stage 3 Blower Cams][JBA Headers, Magnaflow Tru-X, Flowmasters][11.89@119mph] |
Have you checked the coolant level? Is there any signs of coolant under your stang. What about the coolant over flow cap, did it maybe spray inside the engine bay? I did have this happen to me one time.
Just throwing different ideas at you, to try and help.
Average
the coolant is alright and full, and i smelled it and it smells difrent from whats in the sparkplug well thing
Average
ok well i took the compressor and blow that shit out.. and well it smells sweet, and off color but it might just be water with a little anti seize mixed in, because it sweet smelling but not antifreeze and its a little more slippery than water.
1999 GT 35th LE
antifreeze is sweet smelling, and a bit slippery than plain water.
Average
its not anti freeze though, i opened up my coolant and it was full and smells a lot sweeter than this stuff... i think it just rain water, and rain water kind of smells like this.
its like a rustyish sweet smell, its hard to explain but im sure im good now, i just changed out the coil and now my car runs sooooooo much better, when my car is idling it feels like its just turned off, and i can accelerate in 5th gear at 40mph without my car jumping and being jerky |
I would guess it was the intake. I've had both intake and headgasket screw ups. When I pulled my intake off recently, there was coolant on top of the spark plug.
1999 Mustang GT - K&N drop in, Mac Prochamber, Mac CB, 555r's, 31 spline Strange axles, and 4.10's |
Youve got either a busted intake manifold gasket or a cracked intake manifold. Its no big deal, job can be done in an afternoon if you have a few basic tools and a slight understanding of how to use them.
Threads Similar to: antifreeze in spark plug ?
| Champion Spark Plug 7989 Double Platinum Plug | UNVMYGT | 2005 - 2010 | 6 | November 24th, 2011 01:50 AM |
| Demon Coil, IX Perormance Spark plugs,Spark Plug wires? | v6 stunna | V6 Mustangs | 15 | February 9th, 2011 01:31 AM |
| Pulse Plug vs. Spark Plug | BlckBullitt01 | 99-04 | 4 | May 18th, 2008 02:51 AM |
| Spark plugs,antifreeze, oil and power steering fluid questions for the guys who know | CODEBLUE | 99-04 | 5 | February 25th, 2008 04:12 PM |
| Antifreeze in spark plug wire holes | sorrowfulkiller | 96-98 | 3 | June 11th, 2007 11:24 PM |
