Ever overhauled a modular motor?
Can anyone give me insight into rebuilding a modular motor. I am comfortable building motors but a friend says the modular motor has tight tolerances and clearances. My motor in my Bullitt took a s*** and I would like to rebuild it with forged internals and what not, but is there any issues I might run into. Are there any books or dvd's I can buy that would show bearing clearances, ring gap, blah blah blah. Has someone gone through their motor and successfully rebuilt it without any issues. Any help would be appreciated, still trying to decide my plan of attack.
2001 Mustang GT
8.98 1/8
Check out Sean Hyland Motorsports, you can buy his books or Dvds off of summit and jegs or other places. His website doesnt really show all of his books but he has a couple.
![]() CHECK MEH GARAGE BAMA Performance Drag Team #9 |
1999 3V GT/2007 GT D/D
corner carver
The video above is a good referance but here is the tech manual. It is for a 3V but everything exept the VVT is the same.
http://ww2.justanswer.com/uploads/ke...INDER_HEAD.pdf
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
2001 Bullitt
12.25@110.4
I rebuilt my first modular engine for a Crown Vic in 1995. I learned one thing that's very important back then, and share it as often as I can with people.
I had access to a fully equipped machine shop back then, with boring bar and all. I did not use a torque plate on that engine, because to be honest, the torque plate was $1600 back then, now it's about $500. I did everything exactly to specs, and put everything together, making sure everything was perfect. Within a couple hundred miles, the engine was burning oil badly, and within 1500 miles, a few of the piston skirts were gone. Come to find out, the 4.6 is very succeptible to distortion when the cylinder heads are torqued down, and it actually pulls the bores out of round. After doing some research back then (internet wasn't really around like it is now) and talking to a few Ford guys, I figured out the problem. It turned out that you need to use a torque plate to even power hone these engines in order to keep things straight once the heads are bolted on. That info is a lot easier to come by nowadays, but still relevant, and often overlooked. I've seen quite a few rebuilt engines come my way over the years that had similar circumstances, and they had the machine work done at local places that either didn't use a torque plate, or told them that they didn't need one to do the work. So, make sure anyone who does your machine work has a torque plate for the modular engine, and uses it even to hone the cylinders, or chances are that the engine won't last very long.
Bolt-On Bullitt... Unmodified longblock, stock intake and throttle body. 266rwhp/306rwtq 12.25@110.4 1.64 60ft Currently Under Reconstruction
corner carver
Depends on the block. If it is new or very low miles, just check measurements. With an older block, the above is very true.
1999 GT
This is very interesting!!! I would like to do this same thing down the road my stang has around 130K on it now and they don't last forever.
#7 | |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
02 Mustang GT
9.91@133
Can you buy a set of torque plates from ford? Surely they have to sell them as they build thousands and thousands of modular engines.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
what good is owing torque plates if you dont have the machining equipment.
They arent tougher to build persay, they just have tighter clearances as stated. Still go together like any engine, just a tighter build when done
corner carver
Like he said^
just get some feeler guages and a good quality digital caliper Edit: Oh, and a dial indicater
#11 | |
02 Mustang GT
9.91@133
corner carver
This can be done with a scrap set of head bolted on as well
So is plasti-gauge used like a normal build? And what about bolt stretch and such? That may be in the article above, on my phone, haven't read it yet
any machine shop thats able to write their name with out crayons should/would/will have torque plates
corner carver
plasiguage is fine for bearing clearances. If you are rebuilding dont use cheap TTY bolts. Pay a little extra and go with some ARP hardware
#16 | ||
mm's nitrous mod
2000 mustang gt
depends on what bolts and what all is going on. nothing wrong with using stock replacement bolts in most cases.
corner carver
I know but ARP studs can be reused down the road and if you want to add power dowline it is cheap insurance
mm's nitrous mod
2000 mustang gt
yup, but not all people go that far. stock bolts hold plenty, and holds more than most will ever push.
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
the piston to wall clearence can be a little looser than stock especialy if forged pistons are used. alot of people dont know that the tight .001 or less piston to wall gap is a huge contributing factor to scorched/broken pistons in modulars
2001 Bullitt
12.25@110.4
Explain how you can bore an engine or hone it with a scrap set of heads bolted on please.......
Threads Similar to: Ever overhauled a modular motor?
| Modular Motor Runs 6.25 @ 229 MPH!!! | NastyFX4 | The Clubhouse | 5 | December 2nd, 2010 01:08 AM |
| Modular Motor Shortblocks? | poranksta | 99-04 | 15 | June 16th, 2010 02:22 AM |
| modular motor builders | trent2590 | 99-04 | 30 | June 6th, 2010 01:56 PM |
| How to install MegaSquirt standalone engine management on a modular motor | Matt Cramer | Modular Mustangs | 0 | October 6th, 2009 09:53 AM |
| I want to get my buddy's mustang overhauled but... | Finegan | 2005 - 2010 | 3 | April 17th, 2007 01:26 PM |
