2003 Mustang GT
14.16 @99.03
New cams
I just bought a set of Hitech Stage 2 cams for my car. Does anyone know of a good manufacturer for cam gears or if I can reuse my stock ones, or if the stock ones are removable?
Military Crew - United States Navy - Second Class Petty Officer My 2v build - MMR 1000 rotating assembly, Stage 3 heads/cams, 76mm turbo. Shooting for 700+rwhp. |
![]() iTrader: 1 reviews
I am not 100% positive - I believe the answer is yes. If you have a 96-98 or 01+ you can reuse them. Some people here know the answer to this. I hope they come in this thread.
How To Install Cams on your Mustang - DIY |
#3 | |
Of course if you had 99-00 you would just by cam gears from a different year. Since the 99-00 cam gears are pressed on instead of bolted. If you are looking for adjustable cam gears, I would do some research. I have heard of some of them losing adjustment and causing PTV. Some people just grind the key way on the stock cam gear and adjust the cam that way. If you plan on degreeing the cams you will have to do 1 or the other. I just had a thought. Why do we call them cam gears? I was wondering if maybe if cam sprockets or cam chain sprockets might be a better term?
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Threads Similar to: New cams
| changing mach1 intake cams with 96-01 cobra cams?? | blue03mach1 | 4V / SVT | 19 | November 11th, 2009 02:11 PM |
| lunati cams vs. houston perf. vs. comp cams | mylilboostedpony | 99-04 | 0 | September 12th, 2009 06:05 PM |
| cams cams cams help me pick some cams | tlazyhpony | 2005 - 2010 | 13 | September 4th, 2009 02:27 AM |
