No Pressure after Oil Change - Page 2
Old March 4th, 2011, 01:05 PM   #21
gt_andy's Avatar
13.10@103
gt_andy is on a distinguished road
Send a message via AIM to gt_andy
Originally Posted by Eagle2000GT View Post
Update: After two trips to the parts store I've got oil pressure again. Evidently Ford made a mid-year change. My 2000 GT has a 2001 Oil Pressure Switch. I guess I gave Mobile 1 a bad rep when it wasn't necessary. I wonder what the odds are of the switch going out during an oil change?
Perfectcircle: Yes, the switch is located next to the oil filter and is easy to change. And, you are correct about the stock gauge. It doesn't really measure oil pressure. Its basically an idiot light with a needle. Above 6 psi it will read the middle of the gauge. Below 6 psi it reads zero.
gt andy: It is most likely your switch. It costs $40 at Ford and $9 at Autozone.
I figured it wasnt the pump or the filter... because the car runs fine and still sounds good with no knock or lifter noise...
Is there a pic of this part..? My car is in storge and i would like to get the correct part before i pull it out to fix..
2000 Ford Mustang GT 5spd (TOY)
1997 Ford Tunderbird LX = Daily Driver
Old March 4th, 2011, 01:07 PM   #22
gt_andy's Avatar
13.10@103
do you have a romeo or a winsor motor? I have a winsor motor. you think that will take a 2001 oil pump switch?
Old March 4th, 2011, 02:00 PM   #23
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I have a Windsor. Which switch probably would depend on the build date. I think my car was built in April 2000. You can tell by looking at the switch which one you have. The 2000 switch has a single pole. The 2001 has a locking connector.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old March 25th, 2011, 09:21 AM   #24
gt_andy's Avatar
13.10@103
I just replaced mine over the past weekend. So far so good.. I also had to get one for a 2001 with the plug in connector..
Threads Similar to: No Pressure after Oil Change
Oil change yesterday, today overheating and low oil pressure omam2006 5.0 Mustangs 5 January 24th, 2011 10:04 PM
Need Help with Oil Pressure RaceRelated 5.0 Mustangs 12 June 18th, 2009 12:14 AM
Oil Pressure???? sn94 5.0 Mustangs 1 July 23rd, 2008 09:16 AM
Oil Pressure shurb125 5.0 Mustangs 3 January 9th, 2008 01:55 PM
oil pressure hmotes 5.0 Mustangs 8 January 18th, 2007 09:30 PM
